=X-II-AIRFORCE-ONE-II-X=
copy that bro. boss jay ung valve spring ah reserve na yan heheh\
Mahina ba ung meron bala ng CANYONi used cms no tiktik . oo nga mahina nga motor ko . thanks sa input
boss rowan mas mahala ata ung canister mojeffmac,s place has a lot of mamaw bikes ive been there before.
the only reason i have that pipe coz'i dont have budget for aftermarket pipe.
gusto nyo mag swap ahm payag ako hehehehe
ahahahaha RARE
anyway CMS vs TURBO CAMS...lamang po sa duration ang TURBO un lng ang masasabi ko
sa mahcine shop nsa 300pesos ung valve pocket...pero sa ibang mechanic libre yan eh kung cla mismo ang gagawa kxeOk lang ba ang cms sa stock block?magpopocket naman. planning to upgrade din naman to vixion.
Magkano po bayad magpapocket?
btw made in taiwan ang cms?
http://syark86-pma.blogspot.com/2011/05/new-cms-racing-camshaft-for-135lc.html
ksama un sa work lalo na high lift cams
mga master ask lang ako im using 60mm faito bore up kit, i dnt have a valve pocket instead i put a 3 pcs of base gasket. is it advisable for what i have done? kc naisip ko if im going to have a pocket maybe the compression it affect. help mga measter...Yes will effect compression if ur valve pocket so wide and deep.
