the_one
sinimulan ko n pero ndi ko natapos kgabi bagal ng connection ko eh. tuloy ko nlng mmya. tnx paps..edfaith said:download mo na. gumagana sa akin. sundin mo lang yung instruction ng pag install
ok na po yan sir, masusupport na niya mga bagong softwares ngayon..iceman54512007 said:mga geniuses, jas want to share my laptop specs:
SPECIFICATIONS:
MODEL : VPCCW26FA
OPERATING SYSTEM: WINDOWS 7 HOME PREMIUM
PROCESSOR: INTEL CORE i5-520M Processor (2.40Ghz)
MEMORY : 4GB DDR3 SDRAM (2X2 GB)
GRAPHICS : NVIDIA *GeForce*GT 330M GPU
DEDICATED VIEO MEMORY : 512MB
HARD DISK DRIVE : 500GB (SERIAL ATA, 5400 rpm)
tanong ko lang kung ok na ba itong spec ng laptop ko?
anak ng SERVER n yan ah hahaha..Blackfire said:
sir windows issue napo yan you can try restoring it or if you have a recovery disc puede din po pero kung gusto nyo tangal ang problema talaga format puede din salpak ung hdisk sa ibang pc ang have it repaired with a working copy of windows hope this helps pojolly joker said:sir mga magaling sa computer bakit po yung isang laptop ko eh pagkaopen ko bigla me nagpapakita na ganito
YOUR ABOUT TO BE LOGGED OFF
WINDOWS HAS ENCOUNTERED A CRITICAL PROBLEM AND WILL RESTART AUTOMATICALLY IN ONE MINUTE.PLS.SAVE YOUR WORK NOW.
PAGKARESTART PO GANYAN NA2MAN PAULIT ULIT DKO NA MAGAMIT KC EVERY 1 MINUTE NAGRERESTART SYA ANO KAYA PROBLEMA NYA MGA SIR?HOPE U CAN HELP ME.THANKS...
sir pag ganyan po chipset na sira ng video card pero meron cases na boated capacitor din pero pag boated capacitor bihira ung kusang mamatay ung pc pag chipset naman po u can try po labahan ung vc wat u need to do is babad sa tubig na may joy tapos water level is pantay lang ng pcb tapos pagnilagyan nyo ng joy ung konti lang ung hindi mabula ung laba sir 50/50 wat it does tinatagal ung germs este ung dumi sa ilalim ng mga pyesa pero u need to take out the jumpers and fan syempre..ron197904 said:mga sir, narerepair pa ba Video Card (Inno3d 8500 512MB 128bit ddr2)? two years ko pa lang nagagamit to.. nagkakaguhit kasi monitor ko tapos namamatay na at nawawalan ng signal pero CPU nagana pa din.. para magamit lang computer ginamit ko built-in video card..
sir rich this could happen due to memory, proc or bios can also happen due to over heating hope this could help you could also try cleaning the contact pins of the memory with an eraserrich_havens said:bakit yung pc ko at monitor... pag on kung bigal mamatay...
kahit i directa ko sa socket namamatay pa rin...
sir ano monitor mo? LG ba?..rich_havens said:bakit yung pc ko at monitor... pag on kung bigal mamatay...
thanks sir.pano ko po restore and format eh every 1 minute nagrerestart po laptop ko?shakarl said:sir windows issue napo yan you can try restoring it or if you have a recovery disc puede din po pero kung gusto nyo tangal ang problema talaga format puede din salpak ung hdisk sa ibang pc ang have it repaired with a working copy of windows hope this helps pojolly joker said:sir mga magaling sa computer bakit po yung isang laptop ko eh pagkaopen ko bigla me nagpapakita na ganito
paps toshiba & sony parin akoTHE TURKEY said:mga pafs ano magandang brand n model ng laptop ang maganda ngayon 2010???
ok tlga ang apple kso iba OS ng mac..THE TURKEY said:@sir THE_ONE N SIDRO thanks.anong model ang maganda mostly sa net ako mga sir?ndi ba maganda HP or apple?ano magandang model nila?tnx...ala kc ako masyado alam sa mga comp desktop n laptops eh...need some very good advice before buying again...
