CONFUSED AKO DITO ABT. SA STOCK CARB
bragg
from factory setting (1 5 / 8 ) to my new bigger jets (107.5mj , 22.5pj)
panu po ba ang rotation adjustment sa air fuel mixture???
nid ko pa bang alisin ung airfilter?
SPECS:
OPEN PIPE (YYPANG)
STOCK CARB
tnx :DD
nid help masters!
* DAILY USE LANG BIKE KO
red_is_karma
upgrade ka ng main jet at pilot jet ng mas mataas ng konti kesa sa stock. PM mo si sir traxxas meron sya nun around 300 isa
sniperyaz
sarap niyan lalo na pag naka rcdi niyan :twisted:
X Project
Pag HC (103.5) bike mo, gamitin mo yung main jet ng AC (105)... Walang gagalawin sa pilot jet kahit gano kaliit na increment... From fully seated, buksan mo ang A/F screw 1 1/2 (one and a half turn out)... Make your adjustments using 1/4 turns lang since its a stock carb considering there are no other modifications made... BTW, air screw adjusts both air and petrol, the idle screw is, of course idle adjustment... Para sa stock bike itong advise but if you follow the proper tuning for race bike, pag nag open carb ka PALAGING PLUS 15 sa main jet...
bragg
tnx sa input boss
factory setting po ba e2 ng a/f mixture: 1 1/2 ???
kung gamit ako ng 107.5mj at 22.5pj. aus lang din ba?
what do u mean sa Plus 15 sa MJ.?
city driving and daily lang paps!
tono lang sa pipe
sniperyaz
bragg said:
@sniperyaz - daily use paps
kung daily use papz wag ka ng mag open carb dahil masisira ito mag racing filter ka na lang sir lalo na pag lalakihan mo ang main jet mo papz,, apsok alikabok jan,,, magoopen carb ka nalang pag mga single use like you want to race your bike,, mga fganun sir,, pero papz kung like mo talaga open carb ok go ahead ang akin lang panu tatagal yung life ng carb mo :)
X Project
bragg said:
tnx sa input boss
tono lang sa pipe
Stock setting is 1 5/8 turn out from fully seated... Daily driving pala bakit kailangan mag open carb at mag taas ng jet size? Balik mo yung airbox, itono mo ng maganda yung carb para sa pipe mo...
malasakit80
mga boss gudmorning ask lang po..nka open carb ako 28mm oko at racing CDi...un lang po naupgrade ko sa makina, ok lang po ba ito for daily use not for racing? thanks need your opinion and advice...im arnold from fort bonifacio, metro manila...thanks
bragg
panu po rotation from factory setting (1 5/8) to my new bigger jets (107.5mj , 22.5pj)
SPECS:
OPEN PIPE (YYPANG)
STOCK CARB
tnx :D
sniperyaz
it is ok to use open carb in daily use (not for race) but the life span of your carb will lessen unlike carb with air filter,, it will clog your carb due to the ash (ash place), or any particles mix with air, that can cause carb clogging, if i were you guys i'll stick to stock settings,, because it lessen me worry to my bike and it also lessen me the expenses, :p
bragg
im planning to buy hi flow air filter and i have already my jettings.
baba ko nalang carb ko pag meron na ung hi flow air filter! :D
tnx sa input.
* ANOTHER PLS. :D
X Project
I bet you're definitely looking for power since you upgraded to 28mm carb and R-CDI... Could be tuned to work on your bike but not the best idea... Why change to 28mm if it's intended for daily usage? R-CDI and unrestricted exhaust pipe could provide better performance as opposed to the 28mm that will give you inconsistent carburetion...
bragg
panu po rotation from factory setting (1 1/2 to my new bigger jets (107.5mj , 22.5pj)
SPECS:
OPEN PIPE (YYPANG)
STOCK CARB
hi flow air filter..
input nmn mga master jan. tnx :oops: :oops: :oops: :oops:
BOSS_CHRIS
SPECS:
OPEN PIPE (YYPANG)
STOCK CARB
hindi mo kaylangan 107.5MJ, 22.5PJ backfire lang aabutin mo nyan kung pipe lang papalitan mo. balik mona lang yung 20 PJ mo saka 105MJ nalang ang gamitin mo mas ok pa. ok na yung 1 1/2 turn sa af screw tested na yan hth. :wink:
ps: hindi kasi porke malaki jetting malakas sa gas bibilis na motor mo. tamang tuning lang kaylangan sa stock na motor. :roll:
