sniping_area
LESSON 3
CAMSHAFT
Converts the rotary motion of the crankshaft into reciprocating (up and down) motion needed to open the valves. The cam opens the valves, and allows the springs to close them at the right time.
...more than any single other part, the camshaft determines how much power an engine will put out.
The cam times the valves and the engine will not run if cam timing is out.
The width of the cam lobe determines how long the valve stays open, the height of the nose, relative to the base circle, determines how much it opens. The longer the valve is open for, the more the cylinders can be filled, especially at high RPM. Long duration camshafts cause a rough idle because of a loss of vacuum. This loss of vacuum also affects the power brakes.
One of the most common mistakes is to install a cam with too much duration. For the street, stick to relatively short duration camshafts, of around 260 degrees.
Another rule of replacing camshafts is to always replace the camshaft and lifters at the same time. Never replace one without the other, or you probably will get to do the same job again, and soon.
mura na tag TESDA ani
CAMSHAFT
