DIY: 20 LED display Tachometer for Sniper 135
Sidro
EinVer said:
@ goff - my original plan is to put the led display in a separate casing just like your analog tacho (the one ive seen on your pic with the digital speedo)
and place it together with the side mirror
i also thought of placing the leds on the sides of the digital speedo (9 leds each side) but i got lazy with the designing, and sticked with the conventional design hehe
@ elyouch - haven't made one for FE, since I don't use FE (gotta love my fender, specially when visiting my peers in Malabon hehe)
here are some of my LED projects done
tail light (SYM Magic, and Sniper)
paps ask me about sa park light na kulay b blue sa front headlight mo, pano naka install yan pap?
headlight dimmer for SYM Magic
more often, I spend more money in a DIY project
it would have been cheaper if I bought finished products in the market but would be less fun XD
Paps ask about park light na nkalagay sa front head light assy mo. pano mo sya kinabit yung LED?
EinVer
bilog na pcb board, manu-manong putol
para sa suksukan ng led.
tapos glue stick hehe
ordinary LEDs lang yung nasa parklight ko, sinubukan ko lang kung mapupundi
pangsamantagal kumbaga :)
Sidro
EinVer said:
Sidro said:
ang galing mo talaga paps einver. from an audio VU meter ginamit mo yung concept nya into a display panel ng motmotz.. wow! lupet mo talaga!.
you got me there. audio VU meter came into my mind while making it, kaya green, yellow, orange, red ang naging progression leds ko hehe
but the funny thing is, i'd like to make a VU meter for the speakers in my room, but don't know how to. haha
a sparkling super bright blue LED would be nice if it was blinking in synch with the base hehehe
HIndi ko pa nasubukan yan paps pero may na experience me dati sa pagsama ko sa isang mobile. meron sila power amp wid out VU (LED) bumili sila VU and install dun sa power amp nila... yung connections, nag tap sila sa preamp out (Left/right) then used a small wattage stereo amplifier i think UPC 1230 yung IC and then yung output nun small amp dun na papunta sa VU.
Sidro
yung sa front headlight mo paps? yung bright blue, pano mo nilagay? ang ganda kasi sa picz, hindi sya halata na may LED kundi yung glow lang nung light...
dude_pare01
paps question...anong led number nagtitrip ung limiter mo?
at least from then we can make a rough estimate of the graduations of the led
limiter kicks in at around 9000-9200rpm(correct me na lang if i'm wrong)
so if it kicks in at 18th led...
9000/18 = 500rpm per led...
then we can have a rough rpm estimate per led...=)
EinVer
@ sidro - yung nasa SYM ko pala, yung left pic, cold cathode light stick
yung pang computer
yung right side, tig isang backlight ng cellphone nilagay ko dun, di bale yung mismong ilaw ng LED naka direct pasalubong sa headlight para magreflect ng marami sa loob ng head light.
@ dude_pare01 - ganyan nga po ang estimate ko.
roughly 500rpm per LED
I asked traxx about na rpm limit of a stock sniper and he also said it was around 9k to 9.2k rpm
when my 18th LED lits up, its a sure shot that my engine would start coughing up due to rpm limit
this is also the reason why i only used 18 LEDs, even though the circuit can lit upto 20 LEDs
so yeah, i guess roughly 500rpm per LED
and my engine idles at 3 LEDs so roughly 1500rpm at idle :)
dude_pare01
to make it simpler too...
my plan is to just plug two leds...
Green on the 3rd LED...roughly give me the hint that i am on 1500rpm(IDLE)
Red on the 18th or 19th led....SHIFT LIGHT!hehehe...lagot to next week!
EinVer
nice idea. that would make the installation more neat, since there will be less wires.
suggest ko na rin na ilabas nyo rin yung variable resistor sa LM2917, para hindi kayo mahirapan magcalibrate
thats a very good idea bro.
IDLE TUNER and SHIFTER LIGHT in ONE
you also use dual color led
idle green
shift light red
bro design the IDLE TUNER and SHIFTER LIGHT
to help fellow t135 owners
mr_kulafu
@einver,
wow.... ang galing mo paps....hehehehehe... idol!!!!!
mdyo alam ko dn bout circuits, ang galing mo talaga.. tnx for sharing..
EinVer
the diagram on page 1 could be used.
the LM2917 circuit would be the same.
you'll only take out the 2nd LM3914
as for the 1st LM3914:
Pin#6 Rhi - would be directly connected to the +5V
then use the 2nd and 10th LED for idle and shift light
then its all about the variable resistor on the LM2917
i suggest you use 4 pcs 1Mega Ohm variable resistors at first
so you could calibrate the LEDs as much as possible
eto po ang pinaka mahirap na part para sakin
took me 4 runs before i got it right
masaklap nyan, uulitin ko ulit tomorrow
reminder:
- capacitor and resistor values are very important here, since a slight change in value could change the rpm reading
- LM3914 is a LED driver, its output is current driven negative line, so you'll be attaching the negative side of the LED here
(just in case someone didn't notice)
hayz, haba nun ah hehe
sana matapos ko na rin yung sakin bukas para makaattend ako IR Event ng sunday hehe
