Diy Hazzard Light (no Additional Gadget, No Wire Tampering And No Additional Switch)
PiZZNeT
In this TUT I'm going to show you how to make DIY hazzard w/o additional gadget, no wire tampering and no additional switch!!! Just follow the step by step procedure. There is only 2 thing to remind this TUT will work on the "Stock Thailand Turn Light Assy", "Stock Indonesian Turn Assy" cannot do this TUT. I will show the differences of Thai & Indo Stock Trun Assy.
This is a Thai Turn Assy
This is the differences of the 2 Assy
Now this is a Indo Turn Assy
We will now proceed on the TUT... just follow the photo for this TUT sorry for the lo-quality picture i don't have a good cam (This TUT can be applied for both Sniper and Mio (Nouvo have a different turn assy).
1. you need to removed you headlight cover then you need to do the ff.
2.
3.
4. after the screws as been removed this is how it's look like
5.
6. after you removed the small box this is how it's look in the most inner part.
Put back all together the turn light assy and test your DIY Hazzard
(Note: Need to replace your Stock Flasher Relay to a Replacement Flasher Relay b'coz the Stock Flasher relay doesn't have enough Power to turn on the 4 light bulb.)
Here is the proof video on this TUT, showing you how this TUT works
Note: If your SMX are from the Philippine Market mostly have a Indonesian Parts, Sniper R (Some of this model can do the TUT) if you want to do this TUT and your Turn Assy is Indo OEM, you can buy a Thai Turn Assy at 10th Ave Caloocan City Ph or you can order a Thai Turn Assy from BOSS_JAY316
Sorry for my Bad English :confused:
Thanks for for liking :D
Jonmitchell
if you got this one you can use it, just follow the picture how to do it and be remind that you need to change your OEM Flasher Relay to Replacement Flasher Relay it's just cost around 80 petot.
not done but fails to do it, because of so much excitement i cut the wrong onces. :mad:
jcm1130
i have been using this for the past 2yrs.. and its great.. just a little bit of mods and the result is superb..
until now it gives the hazard lights that i needed whenever needed..
like raining hard.. specially zero visibility.. even early morning fog.. and at times while overtaking on a counterflow..
PiZZNeT
oh really is that already 2 years past when I 1st test this kind of hazzard mode on you snipee? i thought that was only yesterday!?
jcm1130
yup!! time flies quickly.. hehe.. due to our busy-ness to everyday load..
just wanna testify about this TUT..
it never fails me.. yet.. haha.. just kidding.. :D
