suiluj
up question-yung saken papz led parklight sa harap okie nman xa... pro kung led parklight gamitin ko sa likod ayaw gumana... ano kaya pwede gawin nito papz???
sir how do install ledz on your rear park light?-yung saken papz led parklight sa harap okie nman xa... pro kung led parklight gamitin ko sa likod ayaw gumana... ano kaya pwede gawin nito papz???
Bro use electronic LED flasher for signal lights. Yung stock flasher relay ng sniper hindi po gagana kung LED gagamitin sa likod at harap na signal lights ng sniper, pero kung may parallel na resistor, gagana po ito.-yung saken papz led parklight sa harap okie nman xa... pro kung led parklight gamitin ko sa likod ayaw gumana... ano kaya pwede gawin nito papz???
sir are your sure parallel connection yung resistor?Bro use electronic LED flasher for signal lights. Yung stock flasher relay ng sniper hindi po gagana kung LED gagamitin sa likod at harap na signal lights ng sniper, pero kung may parallel na resistor, gagana po ito.
Nakadesign kasi yung stock flasher para sa stock bulb ng sniper.
Yes bro, resistor is required to make the stock flasher relay fuctional when using LED. pwede rin parallel mo sa stock bulb yong LED signal lights.sir are your sure parallel connection yung resistor?
aw, thanks papi. Ive already done this before, reason is that set of LEDZ design for park, tail, signal lights etc have a higher resistance compare to our stock bulb and stock flasher relay is capable of handling low resistance lights and design only for 2 lights. And what I do is change my stock flasher relay that can accomodate 6 lights and with high resistance. So that no more add-ons, and it is functional also for hazard lights set-up.Yes bro, resistor is required to make the stock flasher relay fuctional when using LED. pwede rin parallel mo sa stock bulb yong LED signal lights.
No problem bro.aw, thanks papi. Ive already done this before, reason is that set of LEDZ design for park, tail, signal lights etc have a higher resistance compare to our stock bulb and stock flasher relay is capable of handling low resistance lights and design only for 2 lights. And what I do is change my stock flasher relay that can accomodate 6 lights and with high resistance. So that no more add-ons, and it is functional also for hazard lights set-up.![]()
bro...what kind of relay and what brand ur using on LED signal lights..pix may also help..for the benefit of all...aw, thanks papi. Ive already done this before, reason is that set of LEDZ design for park, tail, signal lights etc have a higher resistance compare to our stock bulb and stock flasher relay is capable of handling low resistance lights and design only for 2 lights. And what I do is change my stock flasher relay that can accomodate 6 lights and with high resistance. So that no more add-ons, and it is functional also for hazard lights set-up.![]()
.tnx bro...sir what po ang value ng resistor and watt?Bro use electronic LED flasher for signal lights. Yung stock flasher relay ng sniper hindi po gagana kung LED gagamitin sa likod at harap na signal lights ng sniper, pero kung may parallel na resistor, gagana po ito.
Hindi maganda gumamit ng resistor dahil umiinit ito bro,palitan mo lang ng electronic flasher.sir what po ang value ng resistor and watt?
Kala ko malapit lang bro. Pwede sana kita mtulungan kung malapit kalang. Txt mo lang ako bro pag ayaw gumana LED signal lights. 09194771064pampanga pa po ako sir......
ok pre, ill take pictures of the brand and its specs tomorrow. Regarding of what kind, of course flasher relay for motor vehiclesbro...what kind of relay and what brand ur using on LED signal lights..pix may also help..for the benefit of all....tnx bro...
Bro try mo tangalin bulb ng signal light mo sa speedometer, kung gumana yong LED signal lights front and back, modify mo nalang connection ng signal light indicator. Ito ginawa kong modification then change indicator to led peanut bulb. diode value is 1n4001-yung saken papz led parklight sa harap okie nman xa... pro kung led parklight gamitin ko sa likod ayaw gumana... ano kaya pwede gawin nito papz???
