Do's and Dont's with our T135
kikaipitoy
Do's:
1. keep it clean and shiny
2. warm up the engine before taking off (specially in the morning)
Dont's"
1. sabi daw "dont use low quality tire blacks" bcoz it can cause cracking of tires (it magnifizes the heat of the sun on our tires) instead use armor all bcoz it has UV protection mahal nga lang.
2.Pag naulanan MC natin agad nating hugasan ng tubig nawasa kasi ang tubig ulan daw ay may acid components that could damage the paint of our MC's.
3. Dont call or text while driving our MC very dangerous he he he
share naman kayo ng do's and dont's
eboitot
sir db masama pa din lagyan ng kahit
ano ang gulong natin kasi nakakadulas to
lalo na pag bumengking.. IMHO :D
russell
hmmm...
always keep the chains well lubricated... my maishare lang
at wag magaangkas ng 2 fg ng di nagyayaya ng kasama.. peace..
kikaipitoy
russell said:
hmmm...
at wag magaangkas ng 2 fg ng di nayayaya ng kasama.. peace..
natawa naman ako paps sa "dont's" mo he he he agree ako sayo paps
kikaipitoy
add ko lang parang nabasa ko sa manual na wag loadan ng more than 110kg ang MC natin dont know if combined weight ito ng driver at nung angkas....
eboitot
kikaipitoy said:
yung side wall lang siguro paps ang lagyan para gwapo lang tignan he he he
gumagapang kasi yun from sidewall
to the tires mismo db....
well pwede siguro kung manipis lang ang
pagkaka apply...
dont's?
wag titipirin sa mods.. :wink:
the_one
kikaipitoy said:
Do's:
Dont's"
Things to Check Regularly
Tires, Tyres.
Tip: Keep a low pressure tire gauge (0psi - 80psi) in your bike tool bag at all times. Try to remember to check your tire pressure everytime you fill up for gas.
Brakes
Tip: Brake fluid absorbs moisture over time and becomes less effective. Replace brake fluid every one to two years and your brakes will preform the best they can.
Chain and sprockets, Shaft Drives, Belts
Tip: Lube your chain after each ride when the chain is warm so the oil can easily soak in and get into all the tight spots of the chain.
Fuel
Tip: Check your fuel filter (if you have) on a regular basis and replace every 2 years.
Oil
Tip: Check your oil level when it is cold before you go on a ride. If it is not at its high or max level top it up before going out.
Battery
Tip: Check the fluid levels on each chamber. If any chamber is low, carefully top it up. Use only distilled or deionized water, NOT tap water. Tap water has minerals in it that will not do the battery any good.
pls pls pls DONT use tire black s tires natin its a mortal paps. Just use a rough fabric, water & soap lng lilinis n yan..
kikaipitoy
the_one said:
kikaipitoy said:
Do's:
Dont's"
Tires, Tyres.
Brakes
Fuel
Oil
Battery
very informatives sir..thank you
elyouch
Important on braking..majority of us use front brake..
on UB bikes it is most recommend to use rear brakes most of the time, rather than front brakes. (lalo na pag downhill USE REAR BRAKE and ENGINE BRAKE)
always check your brakes before riding and also your brake fluid.. brake fluid must be clear on color to nearly amber(like beer color) that's ok. every year or 6mos change brake fluid and brake pads. depends on riding habit if you use your bike everyday change pads/fluid every 6months.
check all of ur fairing allen screws before hit'n the road
better be safe than sorry. if you are really a speedfreak do it on the race tracks-
red_is_karma
for me never use full-synthetic base engine oils,based from my experience, nakakasira ng clutch lining eh (correct me if I'm wrong) naubos kai ung lining ko as-in ung mismong bakal n lng natira, pudpod talaga!, di talaga umandar motor ko,, sabi nung mechanic na gumawa un daw ang isa sa mga main reason bakit naupod ung clutch lining ko ng sobra,,, ewan ko kng tama kasi di naman ako clutch driver masyado and wala png 8 months ung motor ko... la lang na-share ko lng
wingman44
There is nothing to correct 'coz you are so right.
the_one
miguelvrazo said:
B - Battery
L - Lights
O - Oil
W - Water
B - Brakes
A - Air
G - Gas
Things to remember
hahaha naalala ko lng ung IRGP paps.. the who itong rider n badtrip s mg mechanic nya kc naubusan ng GAS ung mio nya during d race.. pakshet tlga nagkaroon tuloy ng eksena s PIT nla ;)
eboitot
the_one said:
miguelvrazo said:
B - Battery
L - Lights
O - Oil
W - Water
B - Brakes
A - Air
G - Gas
Things to remember
bwahahaha
kita ko ito paps
may nagwawala
kasi million pala ang inabot
nung mga motor nila...weeeeeeeeeee
the_one
isang taon n pinaghandaan tpos daan daang libo ang motor s halagang 55/lt n gaso ndi n bili ouchhhhhhhh.. :cry:
elyouch
afaik- kung everyday use di tlaga maganda ang fully-synthetic pero kung race used recommended ito..kung sabagay pag mag race halos lahat ng consumables dapat bago before the race..so di nila cguro ma experience na maubod kaagad ang clutch lining nila :lol:
