Drag race T135 version
P@simuno
lightening of flywheel, rcam,rcdi,r ignition coil, valve spring, 28mm carb at iridium sparkplug kaya na yun
Basta wla pa load raider 150 sa engine
SPEED RACER
ano byung flywheel? my pic k ba?
stock sniper 135 can depeat raider 150 as long you have this mode
1. squish-band to 2mm
2. valve pocket piston ( wag masyado malalim baka mabutas )
3. port & polished the head ( mag ingat wag sumubra )
4. if your hand clutch lightened your flywheel and magneto
5. clutch spring
6. racing cdi & ignition coil
7. aftermarket muffler
8. 28mm carburetor
9. 4th gear 21 teeth ( use stock sprocket combination 15/39 )
now you can beat raider 150 even if he use muffler & rcdi..
xxztrumzxx
5. clutch spring
8. 28mm carburetor
Sir displacement nalang stock dito eh.....:p pero toto to kase ganito yung sa tropa ko... cams, big carb, CDI, muffler, sprocket set, clutch spring, tyka cams nakalimutan ko stage, pero mamaw na....
Russel Medios
mga papz yung sken sumisibk ng stock na raider inis nga mga co worker na nka raider. stock 135 yypang cam n 4th gear ang karga ng snipee ko.
Russel Medios
aklan
sir gusto ko nyan matalo stock na raider hehehe
mga master nka s4 evo cam ako mtrt vspring tapos nka pipe na dbs
ANO PANG KULANG PARA SA SNIPER KO?
YUNG PWEDE PONG PANG EVERY DAY USE MGA MASTER.....
john_carlo
walang kwenta ang valvespring mo kung di ka naka rcdi, dahil ganun pa din limit ng rpm mo
Mr.Yozo
012320102635.jpg012320102636.jpgthis was taken i think last two years ago. it's around 190cc as per the mechanic of the bike but unfortunately didn't get any place in open category.
my share :D
