rem
ang mahal pla ng water pump!!!!!!!!!mtrt po sa caloocan kaso nasa 4500 ata price. if you know ivan santiago they say he has surplus electrical water pump at about 2500 ata??
Hi Doc in this photo, you're using stock water pump that connected to your camshaft, for your 65mm cylinder block.View attachment 13986View attachment 13987View attachment 13988View attachment 13989View attachment 13990 View attachment 13986
View attachment 13991View attachment 13992
make your crankshaft heavier to increase inertia needed for the heavier piston. see pictures, (my stock crankshaft with stock stroke made bigger and heavier for more inertia to handle the bigger/ heavier piston). for drag transmission i recommend a gear 1-13/31, gear 2-stock (16/30), gear 3- stock (17/23), gear 4- stock (23)/ 20.
so far haven't encountered any problems at the moment. when you say water spills you mean coolant is getting into the combustion chamber? that could be a gasket leak. i may convert my mechanical water pump (stock) to an external electrical water pump system. the purpose of which is to reduce every possible mechanical drag just like removing the kickstarter mechanism, going for a total loss ignition system (no stator coil). doing away with the water cooling system depends on the size of your engine. the bigger the engine the greater the heat it produces. you don't want to run into overheating problems especially when the engine is all out in a 402 run.Hi Doc in this photo, you're using stock water pump that connected to your camshaft, for your 65mm cylinder block.
question is, do you encounter any problem with your cooling system(water pump), because in my bike always had water spill inside the engine.
also what if i will not use my water pump system is it good for 400meters run? for drag?
i suspected that the water spill come out in water pump due to the 65mm cylinder(X1R) doesn't have way to have a spilling problem, what do you think? i think i should need to convert that water pump into electrical water pump, and advantage is, the circulation of water continous even the engine is not running,right?so far haven't encountered any problems at the moment. when you say water spills you mean coolant is getting into the combustion chamber? that could be a gasket leak. i may convert my mechanical water pump (stock) to an external electrical water pump system. the purpose of which is to reduce every possible mechanical drag just like removing the kickstarter mechanism, going for a total loss ignition system (no stator coil). doing away with the water cooling system depends on the size of your engine. the bigger the engine the greater the heat it produces. you don't want to run into overheating problems especially when the engine is all out in a 402 run.
ngeh..isip isip..Doc....ryt now my sniper is only stock but i want it 2 run on topspeed in 600meters or less...what can u suggest for its set up?f u says 130 or 140+ in 600meters or less im Much happy with that docgabby...pls help
i think LHK is the best gearing for dragI have prepared a table with list of gearings from stock to different aftermarket racing gear sets available in our market today...
please share of which you think woul be most suitable for a 200cc drag bike, Yamaha Sniper...
Please correct me if I have entered something wrong on my table... THANKS!
hmmmmmmmmmmm..........i think LHK is the best gearing for drag
-any one comment who are using LHK? tnx
lhk has gear 1-13/31, there is also available gear 1- 14/32 and gear 1-15/31.in my opinion, for drag purpose, LHK has best 1st gear compared to the others...
