E-start Prob
peepooy
Good day mga kol...my current setup is 59mm shaved jvt block and naka UMA starter ako. im having hard time starting my sniper using e-start. im using quantum maintenance free batt. my time na 1 click lang.. my time na medyo delay ng 2 seconds but now ayaw mag start peru ramdam ko ang ikot ng start peru para stockup... pag naka kick start wala naman prob.
linjunvelasco
my friend has the same problem with yours, 59 JVT and uma starter, brand new battery pang raider pa 2 months lang
uma starter gave up,,, its a good thing the starter is still under warranty..
ESOJ de GUZMAN JR
Same problem I experienced with my previous mc wave125. New battery pero ayaw mag start. At ung tunog prang nglock pro pgkick ok nmn. Check nmin ung starter at ung sira ay naalis ung magnet sa loob ng starter. Dinikit lng sya gmit ung steel epoxy ok na at sbay plit nrin ng carbon brass.ok na.
peepooy
na solve yun prob bro?
peepooy
we havent talk yet kasi babalik daw sya sa GSD ...delay ng 2 secs yung e start nya before
yun sakin naman bro, stock starter ko sunog, kaya nagpalit akong ng UMA starter para hindi mahihirapan mag estart... at first ok naman yun UMA ko... 1 click start agad...para stock engine lang, now biglang hirap mag start. pag estart ko para tunog naglalock....
ESOJ de GUZMAN JR
cguro sir naalis ung carbon brass nya.
jangbest
Sobrang taas siguro nang compression kaya di kaya nang e start
john-locke
the probleme is not the battery but the cable . change the cable section 6mm2 original with a cable section 16mm2 : the power cable and the negative cable too . that resolve the probleme .
i have installed on my bike a renforced starter motor as the uma but from other compagny and the cable 16mm2 resolve it . now the the starter is a veritable turbine power ...
