Elec. Wiring for LED Parklight and Tail Light
ronnelmarc_21
so you're going to use LED right?...u just need Diod for rectifying AC and resistor in series with your LED to limit the current and avoid burning out,...
1K ohm resistor will work,..and 1N4001 diode is OK.
thopiang
sir my led taillight keep on burning after several days of use, what seems to be the problem. i used those double contact taillight with lots of led bulbs.
thanks
ronnelmarc_21
you should put a resistor paps,..1Kohm will work for each LED to limit the current,...out taillight has AC and DC,...the Blue wire is AC and the Green wire is DC,...for signal lights are AC,...you need to put a Diode first before you connect your LED especially on AC power to convert to DC,..
LED is efficient bulb need only small amount of current and produces bright light,....work in DC only...
pugo08
just wanna share my DIY LED light.
sorry for the quality. using camera phone.
[video width=400 height=350]http://www.youtube.com/v/5IJ9Qz9hbEo&hl=en_US&fs=1&[/video]
