Electronic / Electrical items for motorcycles
EinVer
lospeeder said:
reserve one sir nag pm n ak sau..
nasa LBC na po, bukas daw marereceive nyo na, as per the LBC guy i spoke with.
@ all - nakareserved na ang stocks ko dito for shipping bukas, at installation sa saturday.
sa mga interested po, place your order na lang thru PM para maisama ko yung bilang sa mga ipapagawa ko.
hopefully next week, meron na ulit :)
lospeeder
ok sir waiting for tmrw LBC delivery...tia
sir pa pm ng price at ung cell no. mo para makuntak kita buy nlng ako ni2 para less abala pa hehe salamat po sir u can txt me 09285830711 sure buyr po ako
goff_d_p
got my Zbox on order, Now just need a super costom Superbright LED tail light to fit inside my fenderless
EinVer
there will be changes on the pin outs of the ZBox.
before we used 12 pin sockets, it will be changed to 9 + 6 pins sockets
for some reasons, 12 pin sockets are hard to find hehe
changes will take effect for the next batch.
installation process and price are still the same.
ill just update the installation pics that i made.
to those who have already placed their order, i'll send a pm and sms once i get my hands on the next batch.
goff_d_p
in the pic, the ing. wire that gets attached to the solit color wire on the brake plug, this shorted out the fuse, I connected the yellow wire directly to ing, and the turn lites worked, but sad to say the Zbox is not working correctly, I have installed a digital speedo, and the wires to the plug are different that the stock set up. so it's harder to figure out what and where things are going. it's now 6pm and I started this at 11am, It's still not working and i'm just not too sure what else to do.I might just disconnect everything and work on it another day. very disapointed right now.
But i'm still working on it. untill it's done
EinVer
for the ing wire in the pic, the stock brown wire is ACC+ or what you may have called the ignition line, this line turns ON whenever the key switch is turned to ON. shouldn't be of any difference on which wire you use as long as it is the brown stock wire
for the white 6 pin socket, you can disregard the dark brown and dark green connections to ground and IND, just use the park light wire
this will let your signal indicators blink at the same time as your rear signal lights. i recommend you do this, think of it as an advantage to us with the digital speedo (2 signal indicators)
i think i have the same digital speedo as yours, even though it has a different color coding on the sockets for the digital speedo end, you should still have the stock color code on the other end (sockets from stock wiring harness)
ive already sent a few fellows here in YT135, and some from other forums
ive gave them the same procedure for their sniper/mio soul
they didn't seem to have a problem with it
but one things for sure, they got confused with the color codes at first hehe
but were able to figure it out.
btw, ive also included in the packages a printed manual,
i know most people don't read manuals (i do too)
but the answer might just be there :)
goff_d_p
I finaly got it!!!
it all came down to just the two wires on the stock white plug for the speedo. they were the two that were giving me the trouble.
Now I just need to figure out the jumber settings, hehehehe
Thanks bro for the help.
EinVer
hi everyone, we are taking our time in releasing the next batch of ZBox
we will be releasing Version 1.3 of ZBox for the next batch
it still has the same function as Ver.1.2
we just added a few OPTIONAL output functions for the new version
1. 2 turn signal indicator output, 1.2 only had 1. this for other motorcycles that have 2 signal indicators (although this wasn't a big deal)
2. an additional output for blinkers, flashers, etc...
kindly check the table below for what possible function you can choose from (opinions and suggestions are very much appreciated):
