Engine Mods,please Suggest.
dennmay16
14/40, 90/80-80/80 ung tire.. sumasakit lang ang ulo ko sa clutch plate pressure bearing,,pero madali namang makabili ng bearing na to,, dahil kasi sa tigas ng clutch springs kaya nasisira,,pero matagal naman,,
anu rcdi gmit mu pre??? ok rin lng ba mg clutch spring zero lng aku??? salamat pre ha
mga master, newbie here :) balak ko sana mag upgrade, ung tipong pang everyday used pwede pa, im planning to have rcdi, racing cam, and racing valve spring, anu po ba mga magandang brand ng mga yan? and sa cam po sana khit stage 2 lang, totoo ba kpag nag cam mag papa valve pocket pa? anu po pwede nyo i suggest sken mga sir? stock engine lang po ako, wala din po plan n mag bago ng block. tia
AJM
@luigi yes sir u need to set ur valve clearance, dnt worry just tell the mechanic to set it for u, he knows that already but make sure the mechanic is good in tuning up motorcycles.
Jiou de Leon
depends on the cam profile bro. if ur on stage 2 cams u need to pocket ur piston so that the valves won't kiss the piston.
Jiou de Leon
H
Thankyou po sir... stock cam lng po gamit kong cam profile...plug ang play nlng ba yan???
d kita ma gets. anu ung na mean mong plug and play? ung valvespring? kung valvespring plug and play lng yan. papalitan lng naman yan eh. ingat lng sa masyadong matigas na spring baka ma pudpud valve tappet screw mo.
luigi
Uhm i mean po ung cam profile ko plug and play kea??(stock cam lng nmn po un na grinded lng)
