Engine Oil
MasterJAD
former user of Castrol power 1 semi-synthetic for almost 1 year..
when we change the clutch springs and linings due to sliding issue, we noticed that theres a lot of
debris in the engine specially in clutch housing..
so we decided to changed the brand of oil..
is this for real? so does it mean that this semi synthetic can cause damage in our clutch? my friend is using this for 1 year and 6 months for his stock sniper but it still runs in good condition...if this the case, then i'll switch back to mobil1
febe gienel celebria
how much is the mobil1? wat number papz? 20w 50? 10w 40? mineral or semi synthetic?
MasterJAD
20w 50... 220 pesos....
899 for fully synthetic
480 semi synthetic
i find mobil1 expensive that's why i changed into castrol...since i have a friend that uses it...maybe, what rhoitol is talking is his engine is not stock...that's why there's a lot of pressure in his clutch. IMHO :)
480 semi synthetic
too expensive... hehe shell advance semi synthetic.. ax7... any feedback papz?? i thnk so .. that his mc was modified already
480 semi synthetic
rhoitol
im not kidding sir, im not against any oil but that was my feedback to castrol.
yah, the engine responsed very good, but after 500 km of running the oil, the engine was too hot and lazy..
maybe i'll try to go long distance .. after i fell unsatisfactory.. i'll change my oil to shell advance ax7
Tagalog: ako din, castrol power 1 semi synthetic...very nice talaga ang engine sound...very smooth acceleration...mura pa...250 pesos lang
English: me too... i use castrol power1 semi synthetic. the engine sounds very nice and the acceleration is so smooth... it cost only 250pesos
for everyday use short distance or long distance.. it's ok to use castrol power1 semi sythetic? sometimes i travel for 100kms. bt usually i only travel around the town... roaming around.. hehe frequent shfting...
rhoitol
try to use other brand of oil..you have the feedback to castrol power 1 right?..
so that you can compare each other sir..
MasterJAD
i have travelled 200kms+ going to province back and forth...nothing wrong with my castrol power1...on my next change oil, i'll try top1 evo or shell ax7.
Castrol Power 1 4T 10w-40 (Formerly Castrol Power 1 GPS 4T 10w-40) semi-synthetic motorcycle 4 stroke engine oil is advanced, premium quality, part synthetic 4-stroke engine oil designed for high performance bikes. Its Power Release Formula is specially designed to enable your bike to deliver maximum and sustained power right up to very high operating rpm thus offering a significant advantage over conventional motorcycle engine oils.
Castrol Power 1 4T 10w-40 (Formerly Castrol Power 1 GPS 4T 10w-40) semi-synthetic motorcycle 4 stroke engine oil is suitable for all modern motorcycle engines where API SJ and or JASO MA-2 (T 903:2006) specifications are recommended.
Castrol Power 1 4T 10w-40 (Formerly Castrol Power 1 GPS 4T 10w-40) semi-synthetic motorcycle 4 stroke engine oil Power Release Formula reduces internal losses in the engine, whilst retaining optimum wet clutch performance to ensure the efficient transfer of power to the rear wheel. Castrol has been designed specifically for motorcycles, and incorporates Trizone Technology™ for the combined protection of the engine, clutch and gears.
