Engine Oil
Ermon
MGA SIR anung oil maganda pra sa sniper MX ko?? ung aalagaag makina ko.. ginagamit kasi sa mahabang byahe e..
tested so far...
1.) Shell advance Ultra
2.) Shell Ultra AX7
3.) Yamalube
4.) Castrol Power1
5.) Repsol Sintetico
6.) Putoline Oil
7.) Zic VHVI
Best oil is Shell, Putoline and Repsol for me. Any oil is good as long as you change it every 1000-1500KM (Stock Engine).
ESOJ de GUZMAN JR
ok sir. tnx for the info.. but someone told me that when he used repsol oil. he got clutch slip and damage the clutch lining. specific oil you used for repsol. i want to use semi-synthetic. not the synthetic one.
MickO_HCMC
im using shell advance engine oil..
wat u guys prefer is good for our bike engine?
I am using Motul 300V full synthetic, no problems so far
current bike spec is:
Yamaha Exciter (T135 in Vietnam) 183cc
UMA Racing super-head (sport) 23mm inlet/20mm exhaust
UMA Racing cam
63mm Malossi bore kit
Malossi Electric coolant pump
28mm PWK carb
UMA Racing coil and lead
Brisk racing spark plug
Shorai Lithium Ion battery
BMC Pod air filter
Stainless header pipe (with modified standard muffler approx. 33mm end bore)
Oil cooler (KTL Tecnic)
Stainless steel oil filter (FLO)
Racing clutch springs (Std. plates) (fitting UMA Racing Hyper clutch soon)
UMA Racing / IMC RCDI
Transmission Standard 5 speed (Thinking of fitting CMS Racing 6 speed)
15F/41R sprockets (Hoddaka)
Chain (428 VX DID)Standard front forks
295mm front disk (RB) with standard caliper
Standard swing arm (fitting HKS banana swing arm soon)
RPM rear mono shock (rebound adjust)
std. rear disk and caliper
Tires F; 70/90 R; 100/80 Michelin Pilot Street
Sniper-Raptor
Bro i highly recommend BARDAHL MOTO 4 PLUS OIL. Then you add about 85ml of BARDAHL B1 engine treatment. I'm using this brand of oil in all my vehicles. You can search their website for you to find out what are the advantages of this oil.....
Sniper-Raptor
