mark anthony landayan
where do you buy your oil guys? dami fake oil sa market.. kakatakot hehe
Bike now 95000km, oil change every 10000km....engine still good but the clutch is a bit noisy, mobil 1 5w-50 fully syn....synthetic oil really good for our engine?
Any brand of motorcycle engine oil will do. .just choose the higher grade like 10w60 or 10w50. .if you can find 5w50 or 5w60 it will be the best. .guyz wat engine oil do u use or preferred 2 use in our t135 m0ped?
-yamalube perf0rmance
-shell vsx
-castrol power1
-petr0n sprint
-motul
-elf
-others
f ders other brand of oil u use pls menti0n and give us d benefits,g0odness and advantages of dat oil 2 our m0ped. . .
Additional input. .regardless of being synthetic, semi or mineral based just refer to its grade. .Any bra
BRO TRUE IM FROM MALDIVES TOO .. I USE YAMALUBE I WOULD REALLY LIKE TO TRY A BETTER ONE .it's a real downer that we cant get motul or repsol in maldives...sure would love to check out the difference between these everyday junk and a high performance oil![]()
Just an advise.. NEVER EVER COME BACK on that mechanic who told you those things about engine oils! Loli'm using motul 10W-40 engine smooth and doesn't have any problem until now. i did ask mechanic which spec is good for our bike, this what they suggest:
1) 0 - 5 years old bike = 0W or 5W
2) 5 - 10 years old bike = 10W
3) 10 - 15 years old bike = 15W and above
whether 40 or 50 it depends, if u shoetr distance traveller suitable for u to use 40 and if u long distance traveller recommended to use 50 because it can withstand high tempreture :mrgreen:
what is your basis? There is logic to the statement. Newer engines have tighter clearance that require thinner oil. As your engine gets older, you need a slightly thicker oil. Old engines with big clearance, need thick oils. Although the age is not really the exact measure of engine condition. Thinner oil is lighter thus more power and better fuel efficiency. But if your engine is already loosing compression, a thicker oil can help lower oil consumption. Best oil is no question, full synthetic. It can maintain its quality longer. Except for Mobil 1, all oils are mineral oil. Additives are added to attain synthetic performance.Just an advise.. NEVER EVER COME BACK on that mechanic who told you those things about engine oils! Lol![]()
Better than what oil? Please state the oils you are comparing. Remember also that every change oil is generally better since the new oil is new compared to a depreciated old oil. Unless your new oil is a crapy one.I'm using Motul 3000, smooth and better acceleration for topspeed
I've used Yamalube new, Power1, Shell Advance, all change in every 1000kmBetter than what oil? Please state the oils you are comparing. Remember also that every change oil is generally better since the new oil is new compared to a depreciated old oil. Unless your new oil is a crapy one.
I bet you that if you put power1 in your next change oil, it will again be better. The oil you change is already burned unlike your fresh new oil.I've used Yamalube new, Power1, Shell Advance, all change in every 1000km
I have used power1 for almost 1 year, engine is always hot, yamalube and shell is better for me than power1, power1 change oil every 1000kmI bet you that if you put power1 in your next change oil, it will again be better. The oil you change is already burned unlike your fresh new oil.
