F/S DBS API HI END IGNITION COIL
oicat
Selling original dbs API ignition coil
guaranteed excellent output
used and proven by champs
for all types of MC even used by team takeshi in IRGP
limited stocks only
1.7k fix
09151140220 sure buyer only
Undah-Bone
basta DBS API wala akong masabi.. samahan mo pa ng dbs api stage 2 CDI + NMF 13 cut and FCCI stage 2 cams.. awww.. memaw..
the_one
a simple tutorial on how to install the api ignition coil..
ignition coil assy
stock ignition coil
remove the plug cap assy (encircled)
after removing the wire from the plug cap (left: stock / right: api)
after installing the plug cap assy to the api ignition coil
after installing the api ignition coil. arrow shows that the wire bracket must be widen so that it will give enough space for the api..
raider125jeigh
ignition coil assy
stock ignition coil
how was it papa jeff
the_one
raider125jeigh said:
ignition coil assy
stock ignition coil
kkainstall ko plng ndi ko p ntest motor ko init eh.. mmya testingin ko kung may nagbago & ill giv my review on this product ni master oicat.. :D
