kr.r_sniper
Prices are subject to change without prior notice and stocks are limited only
Map LOCATION
14.630118,121.069036 <<<~~~ Search nyo po sa maps.google.com
simple and east
CLICK THE LINKS BELOW
http://maps.google.com/maps/ms?msid...ll=14.630116,121.066986&spn=0.009021,0.020599
By kr_rsniper at 2011-08-14
NOTE:
Prices are Subject to change without prior notice:
Sa kadahilanan po na sa CUSTOM TAXES & SHIPPING CHARGES...
Limited Stocks:
Quarterly po kung magpalit cla ng items depende po un sa bagong matutuklasan nila pra mas maimprove ung mga naunang model...
CALL OR TEXT ME +639286144241 or +639151433479
SAMPLE PRODUCTS EXCLUSIVE FOR T135
Faito Turbo Cams
By kr_rsniper at 2011-06-25
Faito S4-Evo Cams
Faito Infinity Block 60mm Bore up Kit
Faito Racing Gear Set (Complete Tranny Set)
Faito Crankshaft 3.5mm (Stroker)
Faito Gasket (NEW) is made from Aluminum Alloy...No Need to Put Sealant
Faito Racing Ignition Coil w/out Ground strap
Faito Sprocket & Chain Assy complete
Faito Extreme Race Break Pad (For Racing use only)
Faito Plug Wire Super Spiral Core
Faito Racing Engine Bearings
Faito Zero Clutch Springs (NEW)
OTHER PARTS & ACCESSORIES
Faito Clutch Carrier Bushing
Faito Thunder Clutch Plate (RACING USE)
H.I.D Mini Bulb guaranteed more than 5,000hrs service life
Faito Air Filter
Main jet #115
Pilot jet #35
Faito Engine Valve Set
For more Products List & Details check the Faito Racing Trend Website
http://faito.com.my/main.aspx
Map LOCATION
simple and east
NOTE:
Limited Stocks:
Faito Turbo Cams
Faito S4-Evo Cams
Faito Air Filter
Main jet #115
Pilot jet #35
