F/s For Engine Modification Purposes "racing Products"...philippines Market Only
Paladin
Padala ka kaya ng items sa Norte, try natin kung anong secret meron sila dun.:p
Para hindi OT, musta na kaya yung order kong seat?
labohd
sir kent, ask ko lang kung nid na mgrejet pgnaginstall ng LHK RAIDER VALVE SET? naka vixion nako tas MX motor ko, if ever na mgrejet anong size ng mj ska pj yung kailangan? stock carb ska stock jetting gamit ko, maraming tnx po
kr.r_sniper
ung tuner mo nakakaalam nyan...in that matters wala po aq idea kxe it depends sa mech na maginstall kung mag rechamber p cya or hindi na!!!!
kr.r_sniper
thanx
sir kent. pm mo nlng ako sir f ok na. and wat is best? vixion spring or tk?
the best TK :D kso mods pa kxe dun dahil masyadong stiffer ung valve spring :D not unlike Vi-xion 12,500 max rpm :D PLUG AND GO...
alternative is CMS (H) 13,000 max rpm & APPI (R-Specs) 14,000 max rpm...kaw na bahala pumili bro pero lahat yan proven and tested na at ung iba race specs...
John Angelo Cantal
sir kent ask po ako, kc newbie lng ako sa engne mods ng snipee ko. i wnt to set up it kawahara k1, i have brt hyperbnd as for nw, dbs pipe, iridium plugs. in ur opinion sir wat was d best valve spring for it. i dnt want to have or float my vakte sir. im using namban stage1 nw.
John Angelo Cantal
sir kent do u have an idea about namban cams? i have it for 5months ht has backfire and the tiktik soundz getting louder specially wen i have out of twn rides. my questin was do it nid valve pocketing? my mechanc sed dat d backfire was maybe bcoz of a gas residue wen i turn off my mc. it was stage 1.
shadow 0389
..the tiktik sound sir is normal,,, just have your mechanic check the valve tappet clearance... at isa pa po,, kapag mainit na makina numinipis viscosity ng oil,, kaya pag longrides normal din po yung mdyo maingay na tiktik sound..:)
..no need to valve pocket sir IMO... tingnan mo lang po na timing tlga.. regarding sa backfire,,, maraming factors yan,,, tono!.... try to check a/f mixture mo, and minsan there are cams na ganun po tlga,, those cams na dont perform well... and minsan due to its lift and duration ng cam....:oops:
..just have your mechanic sir,,, check it just to make sure...:cool:
kr.r_sniper
TIK TIK Sounds is normal it depends on Valve Tappets Settings and your Valve spring if Hardened or much Stiffer than stocks...Stage 1 cams is plug and play...regarding sa backfire check you exhaust system bka may singaw o kya ung sa carb mo or manifold...marami kasi factor yan eh...check all possibility bro...
NOTE:
wag ka hingi advise sakin bro kxe seller ako at hindi ako mechanic...check mo lang ung feedback and ratings nila sa mga items na gus2 mo bago ka bumili...kxe kung ako tatanungin mo natural lang i-bida ko sayo to paninda ko :p to be honest...
PS:
if gus2 mo tlga tumino takbo ng motor mo meron tyo mga mech d2 sa online pde mo cla kausapin at pde mo cla kontakin kung gus2 mo magpagawa sa kanila...for now sila Moto Flash & Rowan gumagawa ng motor namin,ung mga nirerefer namin na payag sa ganung set-up dun din namin pinapadala...by next week my engine will be confine there :D ICU :p hehehehehe
