F/s For Engine Modification Purposes "racing Products"...philippines Market Only
kr.r_sniper
UP FOR AVAILABLE ITEMS...
SYS 6spring Clutch Housing for Sniper A/C 4linings
SYS 6spring Clutch Housing for Sniper H/C 4linings
SYS 6spring Clutch Housing for Sniper H/C 5linings
SYS 6spring Clutch Housing for SniperMX 5linings
IKK Clutch Gear for Sniper HC 4linings
IKK Camshaft Stage 2 w/Bearing 5.8mm lift
UMA High Flow Oil Pump
TKRJ Conrod
CMS Valve set 19/22
CMS Valve Spring
YYpang Valve Spring
APPI Valve Spring
Pro-tec Ignition Coil
UMA Clutch Spring
UMA 28mm/30mm/32mm Carburetor
UMA 62mm Ceramic Bore kit
UMA Piston 62mm + piston ring
UMA Quick throttle
FAG Transmission Bearing
Faito Products
dwayne brandon
TKRJ Conrod
CMS Valve set 19/22
CMS Valve Spring
YYpang Valve Spring
APPI Valve Spring
UMA Clutch Spring
UMA Quick throttle
Faito Products
up up up for super saiyan items...:p:p
kr.r_sniper
TKRJ Conrod
CMS Valve set 19/22
CMS Valve Spring
YYpang Valve Spring
APPI Valve Spring
UMA Clutch Spring
UMA Quick throttle
Faito Products
UP FOR TODAY
