2,500 exclude shipping cost...boss pa pm appi valve spring
thanks bro...
yup!yan ang inaantay ko!! pero dito muna ako sa mx ko!!hehehe.wait lang kr.soon.w8 mode lng sniper MXmagkakaroon din kyo
kung ndi makapaghintay
ibenta si mx bili ng classic sniper
UPNOTE: For Philippines Market Only...No Low Ballers...Price will be change without prior notice...it depends on US Dollars rate...
Paalala na po dun sa puro tanong lang ang gagawin sa text,hindi po ako magrereply...regarding sa price kung anu ung txt ko un na po un...shipping cost exlcude...1text 1 inquiry...deal or no deal lang po...
For Sure Buyer or Orders kindly contact this # 09286144241/09151433479...
Any inquiries regarding the specs of the items just leave a message....Respect my ADS...thank you
RIDE SAFE T135 FAMILY
New Items For Racing Purposes
SYS 6 Spring Clutch Housing "Hand Clutch" (3+1 lining)
TKRH Conrod Kit
IKK Clutch Gear Assy 22T-72T
IKK Camshaft Stage 3
CMS Gear Box High Speed Tranny "High way Purposes"![]()
CMS Gear Set 1,2,4 Gear
CMS Camshaft 5.8mm Lift Stage 2
CMS Valve Spring (H) Hardened Series
CMS Valve Set 19/22
UMA 62mm Ceramic Coated Bore kit Forged Piston
X-1R Hub set (OEM)
By kent_rainier at 2012-03-14
SYS 6spring clutch housing (Sniper H/C 5linings)
SYS 6spring clutch housing (Sniper MX)
SYS 6spring clutch housing (Sniper Automatic Clutch 4linings)
SYS 6spring clutch housing (Sniper H/C 4linings)
IKK Clutch Gear H/C 4linings (22T-72T)
VM26 Mikuni Carburetor Roundslide
APPI R-Specs Valve Spring (up to 14,000 max rpm)
CMS 19/22 Valve set
YY Pang Valve Spring (Japan) (up to 14,000 max rpm)
CMS Gear Set 1st,2nd,4th
CMS Stage 2 Camshaft (5.8mm lift)
TKRJ Connecting Rod Kit
CRG Clutch Spring
Faito S4 Evo Camshaft "Stage 1"
Pro-tec coil Ultimate with Ground strap
IKK Camshaft Stage 2 "5.8mm lift"
Kawahara K1 Camshaft Stage 1
BRT CDI Power-Max Dual Band
RAD Air Filter 48mm (26mm-30mm Carb)
New Items
Leo Vince Corsa "Carbon Fiber GP series" 6,800
AP Magic Quick Throttle 1,250
UMA Racing Oil Pump 2,200
UMA Clutch Spring 600
UMA Titanium Valve Retainer 2,200
BLAZING ITEMSayun oh!! UMA-APOY!!
up!
up!
nakuha mo ba ung exhaust ng tropa ko?!up up sa mga items hehehe
mApapasakin din yan malapit na
upup for sir kent galing talaga.
ah ok...d po sir mag aad pa kc ko 5 hndred sa shipment eh plus pagpapadala ko pa sa kanya kay d nalang muna.
ang gaganda ng items mo ah iponan ko muna para makabili baka brand new nalng kunin ko knte lang deperenxa eh.
