F/s For Engine Modification Purposes "racing Products"...philippines Market Only
alx.cruz
ayos to... Leo Vince ang official exhaust system ng team Yamaha Maju Motor Racing ng Malaysian Cubprix ngayong 2012...
last year kung di ako nag kakamali ay AHM ang gamit nila...
see the shortened GP Corsa Carbon Fiber? :D
(picture is from Racing Boy Facebook)
aizarn20
paps meron k b pang xrm n r. cdi? thx!
sir pag brt gagamitin mo check mo muna kung pang anong model ang ggmtin kasi pang supra kasi ang gngmit sir kelangan mo magmodify ng pulser ng magneto para maging mlakas ang spark sir ng kuryente 22.2 ginawa namin 11.5 na lng ung pulser sir ok na ok ang takbo sir walang limit tlg pero kung ayaw mo nmn ng modification sir sa dio racing kn lng po.sa battery operated nmn sir kelangan tlga mgnda battery mo paghindi wala panay ang backfire sir hirap pa itono ng carb sir kelangan magfast charger ka.
pls ignore na lng po kung hindi nakatulong sir he..he
alx.cruz
wala pong shorty...ung nakita nyong pic na post ni mr. alex.cruz customize made na po un by leo vince...exclusive for sponsored riders...
yup, customize na po yung sa picture na pinost ko...
pati nga pala sa "LC135 Super Series" na category, puro Leo Vince din ang gamit nila...
kr.r_sniper
@ALL​
New Items as of March 12,2012​
IKK Clutch Gear assy 4linings​
SYS 6spring Clutch Housing assy:​
Sniper A/C 4linings​
Sniper H/C 4linings​
Sniper H/C 5linings ​
Sniper MX 5linings​
TKRJ Connecting Rod Kit​
APPI Valve Spring (up to 14,000rpm)​
YYpang Valve Spring (up to 14,000rpm)​
Kawahara K1 Camshaft (Stage 1)​
IKK Camshaft w/Bearing (Stage 2)​
CMS Camshaft (Stage 2)​
UMA Camshaft (Stage 2 w/Decompression pin slot)​
S4 Evo Camshaft (Stage 1)​
Turbo Camshaft (Stage 2)​
BRT Clutch Spring​
CRG Clutch Spring​
Faito Clutch Spring​
CMS Gearset 1st (31T),2nd (29T) & 4th (21T)​
Faito Gearset 1st (31T),2nd (29T) & 4th (21T)​
CMS 20T & 21T 4th gear​
Faito 21T 4th Gear​
CMS Valve Set 19/22​
Hispeed Valve Set 22/24​
LHK Big head assy with 19/22 Valve set​
Mikuni VM26 Round slide Carb​
Pro-Tec Ultimate Racing coil w/Ground Strap​
Pro-Tec Ultimate Racing coil Carspeed Edition​
Faito 7400 Racing coil​
Faito Twin-core Plug wire (HTW)​
RAD Ail Filter 48mm 360 (for 26mm-28mm-30mm)​
BRT CDI Power-Max (Dual Band)​
X1R Hub set OEM​
Faito Crankshaft for A/C & H/C​
Faito Gear box A/C & H/C​
Call or Text for orders 09286144241/09151433479/09321811066...until supply last...limited stocks only...PLEASE No Low Ballers or Bogus Buyer...​
UP UP UP...limited stocks :D
kr.r_sniper
New Items
AP Magic Quick Throttle 1,250
UMA Racing Oil Pump 2,200
UMA Clutch Spring 600
UMA Titanium Valve Retainer 2,200
Also Available Rare Items for Sniper/SniperMX/X1R
SYS 6spring clutch housing (Sniper MX) 2pcs on stocks
SYS 6spring clutch housing (Sniper Automatic Clutch 4linings) 2pcs on stocks
SYS 6spring clutch housing (Sniper H/C 4linings) 1pc on stock
IKK Clutch Gear H/C 4linings (22T-72T) "5pcs on stocks"
VM26 Mikuni Carburetor Roundslide
APPI R-Specs Valve Spring (up to 14,000 max rpm)
YY Pang Valve Spring (Japan) (up to 14,000 max rpm)
CMS Gear Set 1st,2nd,4th
CRG Clutch Spring
Faito S4 Evo Camshaft "Stage 1"
Pro-tec coil Ultimate with Ground strap & Pro-tec coil Carspeed Edition
IKK Camshaft Stage 2 "5.8mm lift"
BRT CDI Power-Max Dual Band
RAD Air Filter 48mm (26mm-30mm Carb)
