F/S Keihin Carburetor PE24 & PE28 from Thailand
kit
May nakasubok na ba senyo gumamit ng 28mm sa stock bore? Yun kc old sniper 22mm lang taz ginawang 25mm sa sniper mx
mag bigbore ka muna paps meron si kent 60mm faito, tapos dagdag ka ng s4evo cam at stiffer vsprings like vixion, huli na yung carb, ako naka bigbore, vixion cam at vixion vsprings pero carb ko ay vm22 parin ng gas ko ay mas tumipid sa 80km-90km distance 140pesos ng pa gas ko, pumapalo sha ng 120km/hr easy easy lang takbo at hindi galit makina, bilhin mu pa unti unti kung limited budget, dats my suggest, ride safe
kr.r_sniper
palitan mo ung vi-xion cams at valves spring mo...tpos try mo ulit icheck ung topspeed :D hehehehehe
Magpalit kn din ng CARB...sayang ung 60mm mo kung ndi mo nman papainumin ng tamang gasolina :D
kit
happy na ko paps sa vixion cam at vsprings ko , hndi naman ako racing, but for sure pag may budget mid sept bilhin ko yang 28mm carb package mo
kr.r_sniper
ahahahahaha...ok paps :D no worries daming stock :D bigtym financier ko kulang na lng hakutin ung gawa ng US at EUROPE :D
CLYDE
Matagal na ako nakavixion valve spring pafs almost 2 years na and brt racing CDI 120kph top on stock rejetted carb 15 x 40 sprocket combi, kapag 42 rear sprocket gamit almost 125kph in 500meters kaya lang para ng sasabog makina. Meron ako Faito s4 evo pro tinatamad magpabukas ulit ng makina kaya nasa for sale section na:D
acidrain
tama ba, na parang biniyak yung kabilang dulo ng manifold para magkasya yung tornilyo? wala bang magiging leak yon? hihigpit ba sya ng maayos? san location mo?
kr.r_sniper
@Jaydee
sensya na bro wala ako knina...kpag sunday tlga bhira aq sa houz eh...anyway next time txt muna kyo bgo kyo punta pra sure ndi sayang pagod nyo...thanks
Method21
@all basic mods na di pangarera..this will help sa setup niyo po...camshaft,valve springs,ignition coil,24mm carb, and a good pipe..basic lang po yan..then you try:p
@kr.r up for you bro;)
jaydee320
@Jaydee
ok lang sir lapit lang naman akosa area niyo tuwing weekend..
brandnew po ba sir yung manifold? plug and play na lang po ba yun sir? thanks!
kr.r_sniper
brand new at sealed po ung manifold :D ndi po cya plug and play sa sniper kxe pang raider cya meron kaunting modification sa turnilyuhan ng manifold :D
Method21
@acidrain stock raider bro?..walang mods..fresh po from the factory?..or nka pipe na?..try lang po ninyo ang mods na yan..kayo nlang po ang mag husga...;)
