mars allan sanidad
can't wait sir kent!mas marami sa sniper classic![]()
TO ALL NEWBIE & MEMBERS LOW BALLERS ARE NOT ALLOW HERE...
ETO LANG GUYS WALANG SAMAAN NG LOOB KUNG 1ST DEAL PA LANG NATIN DON'T EXPECT THE LOWER PRICE DAHIL MAY SRP KAMING SINUSUNOD NG MGA SELLER NG T135 "AGREEMENT BETWEEN ALL SELLER'S"...IT'S UP TO THEM KUNG SUMUSUNOD SILA SA KASUNDUAN...KUNG REGULAR CLIENT KO KAYO OR KAGRUPO KO AKO MISMO NAGBIBIGAY NG FAIR PRICE MINSAN MAY KASAMA PANG FREEBIES KAHIT ASK NYO PA YAN SA MGA NAGING CLIENT KO...LALAKI AKO KAUSAP KAYA SANA LALAKI DIN KAUSAP UNG MGA NAGMEMESSAGE SA AKIN...ETO PA ISANG PAALALA KO SA INYO ONCE NA NAGORDER KAYO OK NA UN WALA NG CANCEL ONCE NA NACONFIRM NA UNG ITEM...OK LANG SA AKIN CANCEL NYO HINDI AKO MAGHAHABOL PERO ASAHAN NYO KAILANMAN HINDI NA KAYO MAKAKAKUHA OR MAKAKAORDER NG ITEMS SA AKIN...AYAW KO NG MGA HAO SIAO OR TRIPPERS DAHIL HINDI PO BIRO UNG KALAKALAN DITO KAMI NAMUMUHUNAN NG PERA AT PAGOD AT LAHAT NG PARAAN GINAGAWA NAMIN PARA LANG MAPANATILING MALINIS AT MAAYOS ANG SERBISYO NAMIN,KAYA AYUN PASENSYAHAN NA LANG KAPAG GANYAN KAYO...
dami freebies and pag dami ka dn order laki din discount
master magkanu r6 tail light at tsaka may faito amber or yellow kabang peanut? sure buyer here please PM your prices..at UUnga pla may fairings kaba gaya ng belly pan basta additional fairings for sniper...thanks in advance...
up ko lang po, this is absolutely true, and mabilisup ko lng boss..lahat ng transaction ko d2 malinis
wala sir ehsir kent do you have osram bulbs or hid kits for yamaha sniper classic 4300k (yellow) with hi/low
ihanap kta sa ibang tropa kung meron...thanks papsup ko lang po, this is absolutely true, and mabilis
antay lang dun sa kulang mong project if ever ndi kp nakakabili sa iba
coming this month
ty papswala sir ehihanap kta sa ibang tropa kung meron...
thanks papsantay lang dun sa kulang mong project if ever ndi kp nakakabili sa iba
coming this month
Sir Kent, pa pm nmn po ung price ng malossi block, head and cams. thanks sir.Malossi Cylinder Block kit 63mm
TECHNICAL FEATURES
Cylinder
Piston
- Bore: Ø 63 mm
- Stroke: 58.6 mm
- Displacement: 182.58 cc
- Compression ratio: 10.6:1.
- Material: primary aluminium alloy with a high content of hardened and tempered silicon, cylinder liner with silicon carbide coating in a galvanic nickel die and crossed smoothing with two diamond passages with very limited tolerances
- Machining: on machine tools with high precision numerical control
- Cylinder-piston connection with an allowance of 0.05 mm
- Recalculated and upgraded heat exchange surfaces
Piston rings
- Ultra compact with 3 rings
- Material: special aluminium alloy with high silicon content, low thermal expansion and a tin facing on the sliding surfaces
- Machining on machine tools with numerical control
- Lightened and reinforced
- Upgraded heat exchange surfaces
- Special rings with high sliding ease and very high mechanical resistance
- I° ring compression in nitrided and chromium steel
- II° special cast iron ring
- Three - piece scraper ring made of chromium-plated special steel alloy.
JACK UP 4.0 FAITO CRANKSHAFT FOR SNIPER HAND CLUTCH...
double kill you have 1 warn pointsbuti na lang mataas credit limit ko kay supermodes hahahaha
yay ang mahalsir kent, mgkano ung faito tensioner? tnx
2,500
