any additional modification done to compliment a 60 mm block?paps ako gamit ko yan 60mm faito block ok na ok sya wala namn problem nakaka 3000km na ako and for daily use pangpasok sa work
ortigas to antipolo
bro no need for additional modification to 60mm faito block its plug in play. same with the faito turbo cam 6.5liftany additional modification done to compliment a 60 mm block?
paps pa pm namn ng pricemeron cla bagong labas na Head Cylinder Gasket...ang kapal aluminum alloy daw ung materials na ginamit pra dun![]()
sir you are a seller of faito products do you have experience on this parts any pros and cons about it?......meron cla bagong labas na Head Cylinder Gasket...ang kapal aluminum alloy daw ung materials na ginamit pra dun![]()
do you mean that a 60mm faito block alone can give power to our bike, even on stock parts such as cam,v.springs,and carbsbro no need for additional modification to 60mm faito block its plug in play. same with the faito turbo cam 6.5lift
if you use 60mm bore kit. you have to change your camshaft that will match to your bore size our stock cams can't give the power that you want and its hard to tune it. Use stiffer v. springs ang use big carbs for that[/quot
plan to modify my bike but can only do it one at a time since parts prices were so expensive here.. so can i install a 60 mm block now without having to chance other engine parts, but will replace them later ...
sir 60mm po yan diba, ilang cc na po yan ngaun? 170cc? kaya pa ba paandarin ng push start?gamit namin sa sniper yan paps wala naman kaproblema problema, nung pagkasalpak binayahe kagad sa pampanga dau, tapos pampanga to paranaque. s4 evo lang ang cam na ginamit namin at kitti v.spring, Xbox kitti racing cdi,kitti clutch spring at stock clutch lining maning mani lang talaga ang 120kph stock carb lang po gamit niyan ha naka open lang at naka rejet ang main jet.
