faito racing performance for sniper 135 in PH.
odie
caloocan po sya sir natanggap kona po flange, up for you, ok po ka deal sir mcid madali transaktion 2 thumbs up!
sniper_eds
pafs ano kasama sa block? ask ko lang kailang ba ng aftermarket valve spring or pwede lang stock kung naka faito block? thanks..
emcid_ubp
madalas nasa caloocan ako minsan nasa malabon minsan naman din nasa
tondo paps, malapit sa LRT r.papa station hehehe dami tinatambayan ehh.
emcid_ubp
Faito Turbo Cams for 3200 pesos only
Faito S4-Evo Cams for 2600 pesos only
Faito Block 60mm Bore up Kit for 4200 pesos only
Faito Crankshaft 3.5mm (Stroker) for 9500 pesos only
Faito Gasket for 3.5mm jack up price`to follow
Faito Racing Ignition Coil for 1900 pesos only
Faito Zero Clutch Springs for 800 pesos only
faito valve spring price`to follow wala pa po sa kopya namin kasi to
eto naman po yung mga actual pics ko na.
limited stocks lang po to mga papa ha first come first serve po.
emcid_ubp
okay lang stock valve spring, pero suggest ko mag kitti racing ka muna habang wala pa yun faito valve spring.
CLYDE
yun ba block me kasamang base at head gasket? bka kc wla mabilhan nun 60mm gasket sa sniper, 54 lang stock
emcid_ubp
complete po ang package ng 60mm bore up kit based and top gasket piston pin and piston rings siyempre kasama ang piston
CLYDE
me valve pocket na ba piston? dapat cguro stage 2 cam na faito turbo kaulam nito kaso d naman available.
emcid_ubp
nsa una kong post yung box ng s4 ev0 at 60mm bore up set na wala ng laman yan s4 evo ang ginamit namin kasi okay naman ang lift mataas din pero di kasing taas ng turbo. as of now binayahe yung sniper namin sa pampangga para i break in.
CLYDE
ano po recommended nyo jettings pilot and main, ska what details nyo, mode of payment etc. Tnx
emcid_ubp
may promo package po ako 160cc na gamit ko rin po sa sniper namin
60mm bore kit included the piston pin, piston ring, based and top gasket
s4 evo cam
kitti racing valve spring
salpak nalang po yan wala ng modification
emcid_ubp
updated
may turbo cams na po ako stocks
turbo cams for sniper for only 3200 pesos
s4 evo cam 2 piece nalang po stock ko for only 2600 pesos
