rpacia said:
when changing CAMS, does it requires anything else? Is it safe to switch CAMS eventhough you have stock engine? Please advise, TIA.
bro, rpacia, what i understand its plug n play not because i'm selling this brand but i;m using it as well even those guys that bought from me they are satisfied,
regarding faito anatomy , intake max lift 5.92
exhaust max lift 5.77
the figure is taken using dial indicator gauge i'll post picture,
on stock engine its safe and plug and play even on vixion bore,
no valve pocket required and the duration of of its lobe is more longer ,
so longer duration the more chances we collect air to combustion chamber,
more air more fuel ... so you might adjust or step to bigger jet or it depend on carb size too,
just a cents..
