Feedback For Vixion Cams On Stock Bore Of Sniper H/c
JVIC
share your experience or top speed in this set up guys for adding tips for the newbies. safe ride
hi guys
english please...
If you love stock cams no noise, afraid of racing parts, wants stock maintenance.
go for vixion cam, its a little bit higher specs than stock cam.
ive been a vixion cam user ever since because of no hassle cam with decomp pin.
now im on kawahara cams since it has decomp pin already :D
i highly recommend vixion cam for owners who loves stock parts on their bike.
cams installation must be done with degree wheel to get the maximum out from the cam...when doing modifications.....do it in the correct method.....
We use Uma Racing cams which is race proven and it does not have any abnormal noise.....when you install racing cams, the valve clearance is important too.....for those who are staying in Singapore, visit our shop....and feel the difference after our tune up.....
You must make sure the cam shafts position in the engine matches with that of the crankshafts so that their rotations are synchronized. This is only way you will know if the rise and fall of the pistons properly matches the opening and closing the valves. A few degrees of misalignment can affect the engine's operation dramatically.
kojack
hey guys.. just wanna ask what is the valve clearance for vixion cams on if i were to use it on my factory stock bike... is it still at 0.10mm intake and 0.16mm exhaust
