Sniper-LC4V
Any Faito block users here?
whats your feedback. TIA!
have you already put bore up kits on your bike dude?
you made you head pnp'd?
we are using 60mm faito block, and it doesn't explode..everyday ride from manila to antipolo, sir it depends on the way you break in. This is just steel bore not chrome bore or diasil type. proper break in lang paps at sa mekaniko ipagawa hindi sa siranikopang racing lng daw yan
pero subukan mo araw araw bka sumabog
sir emcid, my benta kb faito prods?? sori for OT. sir cant be olweiz on line i'll just leave u my dgits 09084021768 / 09172480447we are using 60mm faito block, and it doesn't explode..everyday ride from manila to antipolo, sir it depends on the way you break in. This is just steel bore not chrome bore or diasil type. proper break in lang paps at sa mekaniko ipagawa hindi sa siraniko
whats the best way to breakin..kase mga ibang mecaniko sabi hinay hinay lang for 1st 500km..... yung iba naman ride it hard kse matibay naman, lets just remember na this is not the stock bike that can be hard driven from the dealership... please any inputs based on your experience & results.. Faito 60mm bore up..whats the best way to breakin...salamat in advancewe are using 60mm faito block, and it doesn't explode..everyday ride from manila to antipolo, sir it depends on the way you break in. This is just steel bore not chrome bore or diasil type. proper break in lang paps at sa mekaniko ipagawa hindi sa siraniko
tama po yung sabi nung mechanic na yun sa kadahilanan na steel bore siya, ehh babyhin po ang pag break in wag po hard brake in kasi di pa lumalapat ang piston rings ng maayos. kahit 2 full tank lang sir okay na po wag lang mangigil sa throtle habang bine break inwhats the best way to breakin..kase mga ibang mecaniko sabi hinay hinay lang for 1st 500km..... yung iba naman ride it hard kse matibay naman, lets just remember na this is not the stock bike that can be hard driven from the dealership... please any inputs based on your experience & results.. Faito 60mm bore up..whats the best way to breakin...salamat in advance
yun lang hehe pwede kapag i bre brake in mo muna, pero after i break in much better open pipe na po para di masakal ang power, maski yung dbs na class A pwede na po yun di niyo naman ipang re race ehh.pede po itong 60mm faito block sa stock pipe...
ohh y y? kami sir dito puro naka faito 60mm bore up kit, walang ka problema problema? yung isa kong tropa ginawa niya pang lighten yung piston wala din problema?dami na sira d2 sa davnor faito 60mm..![]()
uu naman sir madalas nga tito ko may gamit ng sniper ehh araw araw na pasok sa pier, r.papa going to piersir so ok dn po ang faito 60mm bore up kit..for everyday use?ska kahit long drive?
