docgabby
opo naman daily driver ko 208cc.thopiang said:sir X, puede pa set-up ng 200cc pang daily and long rides hahaha
SEX-C boys salute you sir X hehehe
this is the straight pin crankshaft i used in my daily driver. its a plus 3 mm offset crank for a stroke of 64.7mm straight pin for more durability. i used a mio conrod plus 7mm same length as stock with pin 15 (plus 9mm mio conrod was not available, for a higher conrod length to stroke ratio). i used a cbr 150 piston 63.5 mm. my big valve head is 22in 19ex using raider valves. i changed my radiator to from that of honda dash for better cooling and bigger fan. cdi, cams, exhaust pipe are all non stock. i changed the tranny to wide ratio for touring. it i want to use it for drag i have to overhaul the engine and install a close ratio.
OK? HEHEHE
