agent*mike
The success or failure of your lighting upgrade efforts rides on the quality of your parts and the quality of your work. It matters how carefully you route wires to avoid chafing insulation. It matters how well you solder connections (crimps and sloppy or 'cold' solder joints corrode and die). It matters how well you shield added wiring from road spray. It matters that you use fuses in the new wiring to protect against vehicle damage due to a new or old electrical fault. It matters that you use high-quality parts that are designed to stand up to the rigors of motorcycle usage. Such components must be resistant to a wide range of temperatures, road splash, fumes found under the flaring of every motorcycle, severe and prolonged vibration, etc. It will pay you to select only the products of companies with well-established reputations for quality and durability; your bargain no-name relay could easily kill you when it fails on a dark road somewhere, leaving you with no lights. Do not purchase vehicle components based solely on price!
Price for single kit with installation:
P 2,500 Single beam
P 2,800 Hi/lo
Hid kit without installation: Retail
P 1,600 Single beam
P 1,900 Hi/lo
Hid Kit without installation: Wholesale minimum of 5pcs
P 1,300 Single beam
P 1,600 Hi/lo
For inquiries call or text @ 0928-5074545(Smart) 0922-8052683(SUN)
No additional charges
P 2,500 Single beam
P 2,800 Hi/lo
P 1,600 Single beam
P 1,900 Hi/lo
P 1,300 Single beam
P 1,600 Hi/lo
