pwde mo naman kick start at ibyahe ng konti para uminit.. eh kaso ang nangyari sakin wala na ko gas sa bahay palang..pumunta ako sa petron..pagdating ko petron ayaw bumukas ng de potah..balik ako sabay tulak..tumirik..kinabukasan ko na pinagawa..naginom nalang ako... :lol: :lol: :lol: :lol:
thats what you called, Double murder.
no gas at the same time busted power lock.
hehehe
there is an emergency way to open your seat manually.
Solution #1
Remove the screws in your fenderless/underneath
then move the fenderless so that you can insert a wooden stick and
push the lock striker.
Solution #2
or using "alambre" , form it like a hook and pull the short cable.
Solution #3
If your battery is weak.
REV your engine and push the seat opener button.
revving the engine will give enough voltage to operate the seat opener.
it will work even if your battery is weak
Everything has solutions
