fork oil
dude_pare01
Sidro said:
ako rin replace narin fork oil. anyone knows what is the exact volume of oil for each fork? Or its just a tantyameter?
60-65ml
tantya?no no no....diskarte!use a syringe na tinanggal ung needle(buy those big 30ml ones para dalawang kargahan lang). No more tanta at exacto to the last ml yan
lml_sete
waaah 3 years na snipee ko diko pa napalitan ang fork oil pero ok pa naman yata eh hinde ko naman malaman kung malambot o hinde basta nagana siya hehehe.
Kaso parang malapit na masira yung rubber fork seal ba yun.
goff_d_p
Here's also a heads up. I have a RacingBoy fork brace, been using it for a few years now. I noticed with the fork brace was on I had a lot of strange noise coming from the forks, thinking the reason is bad fork oil I changed it and re-installed all parts, the noise was still their, so I took off the brace, Noise GONE. strange thing is, I could not find the reason why the brace was causing the forks to work improperly after it has been working fine for many years. so for now I am brace free and smooth riding.
kardel
aha pasensya na naopen ulit tong thread na to...
ibig sabihin palitin na ng oil ang shocks ko kasi:
sa FRONT SHOCKS, pag nalubak pababa o pataas ng biglaan, may parang pumuputok na sound "PAK!" sa harap, di naman tumatama ang fairings,
then sa REAR SHOCK naman, feel ko laging malambot gulong ko, laging naiiwan likod pag kurbada, diretso naman gulong ko...
ano suggest niyo? kano kaya ALL IN ALL paayos ng shocks? Change shocks na ba ako or repair lang? kaya ko ba mag DIY?
penge naman kodigo please? :)
boldstardex
change for oil sa front shocks mo sir,
yung sa rear na man, i check mo muna,habang hindi nka side or center stand ang motor mo, i push mo sya sa upuan or sakyan o, pag maramdaman mo na spring na lng nag dadala ng play, palitan mo na ang shocks mo or pa repair mo po
kardel
tingin ko nga spring na lang, ang talbog la na resistance... :/
sa harap naman okay na siya nilagyan ng oil ubos na pala
kardel
so far okay naman siya, nawala na yung bouncing problem ko sa daan lalo na pag may angkas...
then mas stable na ride ko sa hi-speed...
mas mataas lang ng kunting-kunti sa stock halos di halata pag nasakyan...
feel ko sinlambot ng stock,...
medyo kita sa ilalim...
tolitz
I just changed my fork oil the other day and the oil I emptied from each fork was 100ml.
the proper way to refill if you don't know is when you empty the old oil undo the bottom end allen bolt. let stand upside down for full drain. also remove spring befor draining. when you go to refill, tighten allen bolt, push down the fork tube place spring inside use a funnel to pour the new oil untill it reaches the top of the compressed fork tube. then pull tube up and reinsurt to fork tree. your done.
My machanic that works for Yamaha ( big bikes overseas) showed me how to do it the right way. if you try to do it with the fork tube pulled up you could end up with air inside and it wont work properly. tested and tried to prove it myself, it's true.
Just hope that helps for anyone who doesn't know how.
sir i have question about what you posted what do you mean by this when you go to refill, tighten allen bolt, push down the fork tube place spring inside use a funnel to pour the new oil untill it reaches the top of the compressed fork tube. then pull tube up and reinsurt to fork tree. your done. how about the correct volume of the fork oil?
