Front Fork Housing - Oil Seal (mio To Sniper, Is It Fit?)
bhek_21
Guy's I'm just wondering, many aftermarket fork housings like combiz, trusty and 7seven speed from mio can be adopted to our sniper (probably applicable to sniper mx also). Our fellow riders just transfer all the internal components of their stock fork housing to the aftermarket and then presto! it fits good! You just have to change the disc rotor they say.. Or we could just use the stock fork housing of mio.
So if this is the case, the fork oil seal of sniper fits to mio and probably would fit vice versa (Mio oil seal to fit in Sniper fork).. Can anyone confirm this?
Thanks!:D
bhek_21
i guess yes...
Thanks sir @traxxas-modifier ! :D :thumbsup:
I raise this question because I'm planning to buy fork oil seal for my sniper mx.. Because I'm considering the stock availability at 3's shops and also the price.. if there is a small price difference (I'm looking for a savings even small amount) and it is on stock, I will buy 1 set mio fork oil seal..:D
suplado010
i think you will have problem when it comes to front caliper bracket..because the stock rotor disc of mio is 200mm only our snipey is 220mm so it mean difference caliper bracket...IMO
bhek_21
Sir even oil seal from honda xrm will fit. Much cheaper
@snypey16
So it is confirm that honda xrm front fork oil seal fits to our front shock? What I've tried before is the DUST SEAL which is perfectly fits to mio fork.. hmmm.. Thanks for the info!:thumbsup: Do you have any idea how much it costs?
I think if you will use mio fork, disc rotor alone should be replaced.. But if this would not fit, maybe we should use the mio caliper bracket.. but I will not use mio fork, I just like to get the seals (Oil and Dust Seals)..hehehe but as per information of Sir @snypey16, fork oil seal of honda xrm fits our front fork.. If this is true and if we have other supporting testimonies, probably this is a very good replacement for fork oil seals and even dust seals..:D
bhek_21
XRM dust seal perfectly fits the sniper mx front fork housing..:D I just bought a pair.. heheheh
There is not problem in my oil seal because when I opened my dust seal, there is no oil penetrating from the inside, so no leak..:D
I've change the oil and put only 60ml fork oil each shock.. But the problem is the play is stiff..
My thinking is that my front fork spring is somewhat a little bit softer than normal, what do you think guys?
What I did is I put a stainless allen bol at the top of the spring as spacer then install the cap to make is slightly stiff..
That's the remedy I did to make my spring stiffer..
I also make sure that when is insert my front wheel axle, it should be easy to install and dismantle, which for me is the sign that my front wheel and fork is in right level (pantay)..:D So far the result is good, but the front fork play is quite stiff,, It's like a race spec because it is not bumpy.. hehehe
Do you think guys it is okay if I'll decrease the fork oil from 60ml to 50ml only?
Thanks!
@snypey16 thanks for the share regarding xrm dust seal for front shock..:D
linemile12
sir what is the size of t-handle that is used to remove the inner tube out of the outer tube, need help on the specific size sir, need answer asap
bhek_21
-for the dust seal honda xrm dust seal???
how about the oil seal???
For oil seal, never tried other other bike's oil seal.. but If we are to analyze, some sniper uses fork housing of mio then just transfer all the seals.. I'm wondering if we can install mio's oil seal to our fork as replacement..
bhek_21
sir i cant find any fork oil in my area,what alternative can you suggest?what oil will i use if there ia no fork oil available
Many says that ATF (Automatic Transmission Fluid) can be used.. some mechanics says 2T oil (for 2-stroke engines).. These are alternative fork oils that can be used..
