PA pm....Higher resolution of the dyno
admin... ask q lng po qng ano po ang tamang clearance ng intake & exhaust ng kawahara k1 w/ decom pin, naka vixion kit, cms 19/22 valve set at cms valve spring n ho po ako... thnkz po admin ride safe ho... hope u will help me for this issue... thnkz ang more power...Ikaw bay ay motorista na ayaw ng maraming maintenance?
Gusto mo ba ng NO HASSLE setup?
Just Plug this cam & Play with your bike.
Your bike will have increase of 1.13hp from stock setup as per dyno of motorplus
Its your NO HASSLE SETUP with sure Power
Dyno tested using the ff settings:
Intake valve clearance = 0.06 mm
Exhaust valve clearance = 0.08 mm
Power (hp)
Rpm ------Standard ------ Kawahara Black Cam
5000 ------3,91 --------1,43
5500 ------8,35 --------7,34
6000 ------9,36 --------8,73
6500 ------10,04 ------10,02
7000------ 10,46 ------10,83
7500------ 10,67 ------11,36
8000------ 10,80 ------12,06
8500------ 11,03 ------12,17
9000------ 10,90 ------11,91
Torsi (Nm)
Rpm------Standard------Kawahara Black Cam
5000 ------5,49 --------2,01
5500 ------10,80 ------9,33
6000 ------10,93 ------10,27
6500 ------10,97 ------10,88
7000 ------10,64 ------10,93
7500 ------10,09 ------10,74
8000 ------9,59 --------10,63
8500 ------9,19 --------10,10
9000 ------8,61 --------9,36
yes ok on all stock settings plug and play,good day sir trax, safety ba tong .06mm intake and .08mm exhaust valve clearance for this cam?
susulitin ko tong bakasyon para ma install uli tong nabili ko sayo, 2 months na ata nakatambay,, alam mo na yun. jejeje. mj#105 galing sa sniper a/c andito sa akin, ok na kaya ito? sana mag success na
adjust valve clearance@traxxas-modifier: my mechanic already installed my kawahara black a week or two... is it normal to hear tiktik sound during accelration? im not so sure if my mechanic followed your valve clearance.. is there any way to lessen the tiktik sound? or need to re adjust my valve clearance according to your specification...?
thanks and Advance Happy New Year! =)
once i adjusted the valve clearance bro, will i still be getting the same perfomance?adjust valve clearance![]()
you cannot compare the stock cam at racing cam.With stock block no base gasket .06 intake .08 exaust ok nman.
D nmn tumutukod valve nya..
Ung tiktik sound medyo dinig tlaga compare sa stock cam.
Meron lng sagitsit n tunog sir traxx..
Normal ba yun?or may mali sa settings ko..
soldout k1 cams, feb next sked.sir traxx pa pm po ng price ng k1 black cam,vixion valve spring and ahm m1 shorty for sniper mx.tnx sir traxx
aha...may masamang balak...hahahasir traxx pa pm po ng price ng k1 black cam,vixion valve spring and ahm m1 shorty for sniper mx.tnx sir traxx
