FS: All new version 3 Rextor adjustable cdi
SJLUsniper
sir
For Sale, just arrived after waiting for so long...
ALL NEW REXTOR ADJUSTABLE CDI Version3 (Released April 2010!!!)
-New Hardware
-New Upgraded Firmware
-New Manual
-New Features
FEATURES:
-TPS Tuner
-100% TPS Supported
-Radiator Fan checker
-30 ignition timing curves (auto select thru tps)
-3D ignition timing support
-Thermosensor Support
-Advanced ignition timing 4degrees
-Retard ignition timing 4 degrees
UPDATED FEATURES
Radiator Fan Check
***Radiator Fan check from 4 seconds during key on, now the version 3
only 2 seconds for Fan Check, enough to know your radiator fan is working.
Great thing is rextor implements my suggestion for the reduced time radiator fan check feature :)
Thermosensor
***Thermosensor is more sensitive over stock cdi.
Stock CDI will only activate the thermosensor & radiator fan when
your engine is already overheating.
The Rextor thermosensor has more safety feature
it will activate early the radiator fan even if the engine is not overheating
or if just above the normal operating temperature.
This will make your engine run cooler and maintain its OPTIMUM ENGINE TEMPERATURE.
No more waiting for the engine to overheat before it activates the radiator fan.
Optimum engine temperature = More performance
Ignition curves
***Updated ignition timing curves for better power performance.
This means for every 0.04volts of change in TPS sensor, a specific folder
with graphs is used for better performance. The graphs were dyno tested
to provide better performance on all powerband.
3D (3 dimensional ignition timing) works hand in hand the RPM, Throttle Position TPS and Ignition Timing
to provide the best ignition timing settings at any given load.
Physical
***New hardware and New Manuals
STANDARD FEATURES
- Advanced the ignition timing upto 4 degrees.
Advance the ignition timing by turning the dial counter clockwise
- Retard the ignition timing upto 4 degrees.
Retard your ignition timing by turning the dial clockwise.
- LED red light indicator for ignition timing
You can use this red led light to know if you want to use stock ignition timing or advance or retard setting.
- LED green light indicator for TPS with TPS TUNER.
You will know if your TPS is functioning properly thru this led greenlight.
You can also use this led green light to properly tune/adjust your TPS in your carb in correct angle/setting.
The correct angle for your TPS is important so that you will have the best performance.
REXTOR SNIPER / RAIDER LIMITED STOCKS
PRICE: P4500
thanks
sir traxx available pb rextor cdi mo??
zcbitik
I just want this one but I have a question sir traxx, Im all stock only diff was the muffler where i used tuned hgm pipe, can I still use this rextor even though I am stock, if not, what should I need to replace in order for me to use this rcdi?, how bout the gas consumption? where I can read about replacing cdi for newbie so I can get some knowledge about modification ...thanks in advance sir traxx
xpmove10
`BOUT 9000 TO 9,200 rpm pafs.... OLD TOPIC NA.. pERO SA MANUAL NG YAMAHA T135 UP TO 8500 ONLY MAX RPM...
OUT OF STOCK PAFS.... KAY SPEED MANIAC MARAMI O KAYA KAY PEKZ....
xpmove10
16k lang, pafs ung old rextor ang 18k ung version 3 16k na lang..... tsaka d naman kaya motmot natin 14k rpm kung d ka maglagay ng crankpin na 2.5mm to 3.5m
tataas yung stroke ng mc natin tataas din yung max RPM 12 to 14K RPM....
