Another reason why T135 is the best motorcycle for me,
Complete high quality upgrade parts to choose
FAITO RACING CRANKSHAFT
JACKUP 3.5mm STRAIGHT PIN,
WHOLE RACING CRANKSHAFT ASSY SAFE FOR DAILY EVERYDAY USE
(save your original crankshaft)
Heres the answer to Stroker Pin Fanatics,
No more dangerous stroker pins!
Same or more reliable than OEM because its Straight Pin
-JACKUP 3.5mm STRAIGHT CONNECTING PIN
-SPECIALLY DESIGNED FOR T135 HC and AC
-INCREASE TORQUE
-INCREASE POWER
-SAFE, RELIABLE FOR DAILY USE / LONG RIDES
-THE BEST FOR RACING DUE TO STRAIGHT PIN
Heres the cc equivalent when installed
-stock block 54mm + faito crankshaft =150.5cc 142.7
-vixion block 57mm + faito crankshaft =167.7cc 159cc
-aftermarket block 60mm + faito crankshaft =185.8cc 176.2cc
-aftermarket block 62mm + faito crankshaft =185.8cc 188cc
For Drag Racing Fanatics
-aftermarket block 65mm + faito crankshaft =218cc!!! 206.8cc
Only 1set each type available
PACKED IN A VERY BIG BOX!!!
Picture of stock crankshaft, notice the location of the connecting pin
REMEMBER FAITO RACING CRANKSHAFT IS USING STRAIGHT PIN WHICH IS RELIABLE AS THE STOCK CRANKSHAFT.
See the difference of jackup faito racing crankshaft and stock crankshaft
THIS IS WHAT YOU GET, THE WHOLE CRANKSHAFT ASSEMBLY COMPLETE WITH CONROD, CONNECTING PIN, BEARING.
READY TO INSTALL
READY TO SHIP AVAILABLE FOR HANDCLUTCH AND AUTOMATIC CLUTCH
PM for details
-INCREASE TORQUE
-INCREASE POWER
READY TO INSTALL
PM for details
