FS: Faito Racing Crankshaft (safe for daily use)
Jval Zkie
up for this!
saw it yesterday personally hindi na ako nag tanong ng presyo kasama ko kasi si kumander hehehe... makinis well crafted for our T135
THE TURKEY
pag nagFAITO crankshaft maglalagay ba ng malapad na gasket sa ba2 mga pafs?mas maganda kung ala malapad na gasket pra ndi halata na nka FAITO RACING CRANKSHAFT
JACKUP 3.5mm STRAIGHT PIN...
macoolet
pa pm sir job kung magkano...kausap ko mekaniko ko kanina...sabi mag big valves din daw... :( dagdag gastos
Undah-Bone
may kasama na ba yang gasket fafs? kasi diba kahit naka offset yan uuntog parin yan kung stock gasket lang gagamitin naten. correct me if im wrong. salamat.
haen
im really interested to build another engine using this crank.. but my considerations are :
1. crankcase space (does it have enough space for the new offset ?)
2. crankcase hole space between the conrod and the hole sidewall
3. timing chain
4. gasket
5. ignition timing
6. carb rejetting..
7. max safe RPM assuming piston speed for daily is 20 m/s then max safe RPM is 9500.. but if the crank is good and perfectly trued we can push it up to 12000-13000.. just dont push it too far i think..
but.. there's huge torque gain from long stroke engines and other benefits.. i'd like to know about those things above.. sir traxx, can you ask the manufacturer regarding those matters ?
and if the all new Jupiter MX 5-speed appears we can really get a good engine hehehhe.. maybe using shorter connecting rod is a good solution.. i heard the new Jupiter MX stroke is now 57,9 mm instead of 58,7... that way we can get higher max safe RPM.. come to papa mr. Faito :D
THIS FAITO IS GOING TO FORMER PRES GLORIA ARROYO PLACE :D hehehe
1 more faito remaining...
@all
i cant answer questions as i havent personally installed one yet.
but will install Soon...
im vixion fanatic guy, using the same reliable vixion kit.
i want to increase the CC of vixion kit.
i want reliable parts for my engine as i travel long distance abused riding :D hehehe
Just imagine you have a stroker pin 3.5mm BUT reliable and strong as OEM since its straight pin.
How you can install that, you can ask your mechanic about it.
see faito's description
ONE FAITO CRANKSHAFT LEFT!!! :D
YOUTUBE VIDEO OF FAITO CRANKSHAFT
http://www.youtube.com/watch?v=efBa_D-8TO8
