FS: Rextor Adjustable CDI for T135 and Other Bikes
athlon
Bro traxxas-modifier..
I just use the rextor cdi, but i want to know the the cut off about the CDi..
i also use the koso rpm meter, n i see the cdi kat rev also 10k..
but may original cdi can rev 95OO rpm... .
my question it is the rextor cdi also can rev 10k only..
i real need help.. plz..
Modification:
high flow air filter, iridium denso, neew clucth plate, split fire plug cabel, voltage stabilizer, racing bee power booster..
Rextor Degrees Adjustment
heres the pictures of Rextor Adjustable CDI for Yamaha T135 Sniper Jupiter MX Exciter 135LC Cryptonx(carb version) Spark 135.
Gud pm boss Admin,,available pa ba ang rextor Adjustable CDI,,same price lang ba including the shipping...
Follow up ko narin po yung order ko....tnx...;)
DeViLsToRm
YZ125 is a 2 stroke motocross bike.. it is better in two terms :
1. More expensive (hehehehe)
2. Strong ignition fire (BUT THIS IS AFFECTED BY THE CDI VOLTAGE SUPPLY CAPABILITY.. actually all coil is..)
In general, GOOD COIL MUST BE PAIRED WITH GOOD CDI.. sometimes if we pair a CDI that could supply 500V spark (like Cheetah Power) but the coil cant handle it.. the output would be limited to the coil's output capability.. think the ignition coil as a pipe with certain diameter.. so.. 500V CDI paired with YZ125 coil.. u can imagine it by urself...
Du u min we can use YZ125 Coil for t135?or what coil cud u recommend best?
wateralpha
sir, how can i repair my adjuster. i bought mine 2nd hand. i try to adjust it to stock settings but the red light wont turn on and the adjuster turns 360 degrees.
