FS: Rextor Adjustable CDI for T135 and Other Bikes
marcusfilter
traxxas-modifier said:
Heres whats inside the rextor cdi box
- rextor cdi
- warranty card
- manual in english
- rextor sticker
i am currently using kitti Xbox, rate the 2 cdi from 1 to 10...you're experience with this will enlighten me..
thanks
ride safe
bro
sorry i dont have experience personally with xbox.
why i choose rextor over other cdi is first because
it support 100% tps and thermosensensors.
it supports "real" 3D ignition mapping curves like stock cdi
with adjustable ignition timing.
those are very important to me.
other than that kitti and rextor are both good cdi.
kitti has fixed ignition timing while rextor is adjustable.
rextor uses 3D mapping curves (tps needed)
while kitti uses 2D (since no tps support)
so its really your choice bro.
if you are satisfied with kitti, good for you :)
if not, try rextor... :)
dennis_808
bro trax let me rate those cdi i.e. rextor,kitti and i'll include namban( the red one).on the rextor i'll give it a 9/10 or maybe 11/10 :D it really did improve the power of my bike both torque and power.in short good accelaration and a better top end.the tps and the ignition maps really did there their job plus i dont have to worry if the fan will kick in if my engine is cooking hehe before i installed a bypass switch for the fan so if i think im very slow or in traffic i can automatically turn it on.
For the kitti,i did only used a couple of days running( i swapped it from my cousins,im using namban) only accelaration is slow.i have to rev the engine a bit harder to go to meaty part of its power.but i mananged to run it to 110kph( before only 105kph aerodynamic position) :(
On the namban( red edition),before when my wheel size is stock it used to run up to 120kph but its very unstable so cahnge it to 80/90 front and 90/90 rear.it did improve stability but topspeed is sacrificed only to 105 kph
over all summary:
namban (red)
advantages
-good accelaration ( better than stock)
-goes up tp 120kph on stock tires
disadvantages
-less than perfect top speed
-when changed to fatter tires for more stability,only goes 105kph and maybe 3km of stretch
kitti
advantages
-improve top speed compared to namban with fatter tires.now goes to 110kph with 1.5km of stretch approximately
disadvantages
-accelaration is very sluggish compared to namban as per my definition
rextor
advantages
-very much improve accelaration specially when i advance the ignition timing
-better top speed now i can easily go to 130kph with fatter tires and without the wait hehe
-adjustble timing...good for future engine mods
-with tps better throttle response at all speeds
-supported with fan thermosensor (just like stock cdi)
disadvantage
-sorry guys can't think of any disadvantaged hehe
MASKEDBANDIT07
the Rextor CDI is really making my mouth water...hehehehe...have a question...have you guys tried the rextor using stock pipe,stock filter and fat tires?If anybody has...could you please give some feedback?
bro heres my experienced NOT fat tire but using stock tire only (sorry i dont have fat tire)
-k&n air filter
-stock tire
-stock carb and stock jet
-stock muffler pipe
-rextor cdi
i can get to 130kph (sniper speedo) aerodynamic position.
super long road.
recently using the ff specs
-k&n air filter
-stock tire
-stock carb and rejet
-open muffler pipe 4N
-rextor cdi
130kph? :) you can reach it with just enough road.
120kph? very easy to attain normal position
MASKEDBANDIT07
Yeooowww!!!Rextor will definitely be in my wish list...need moohlah,lots of it...hehehe....one more question, My bike is AC, has anybody tried the rextor on an AC T135 with stock specs?
jkt 9489
wat d difference?
which is better?XP cdi or Rextor? and wat d difference?pls pm me d price including shipping to m'sia...thnx
haen
for stock carb.. i vote for rextor CDI and HOLparts / xp coil whichever u like.. better yet.. rextor CDI and YZ125 coil (4SS)..
for TM carb.. i vote for cheetah power programmable CDI and HOLparts.. (like the one i'm using hehehe...)
dennis_808
haen
YZ125 is a 2 stroke motocross bike.. it is better in two terms :
1. More expensive (hehehehe)
2. Strong ignition fire (BUT THIS IS AFFECTED BY THE CDI VOLTAGE SUPPLY CAPABILITY.. actually all coil is..)
In general, GOOD COIL MUST BE PAIRED WITH GOOD CDI.. sometimes if we pair a CDI that could supply 500V spark (like Cheetah Power) but the coil cant handle it.. the output would be limited to the coil's output capability.. think the ignition coil as a pipe with certain diameter.. so.. 500V CDI paired with YZ125 coil.. u can imagine it by urself...
