FS: Vixion Valvespring and Kawahara Cams (PlugnPlay)
botsok
oo papa admin. no need for valve pockets.. salamat kay papa nacz. ganda ng effect guys! highly recommended. tnx din kay sir chiglai.
cqwuzhere
traxxas-modifier said:
hi guys
For Sale: Vixion Valvesprings and Kawahara cams now available.
Plug and Play
VIXION VALVESPRINGS
Tried and tested for long rides, tested for racing use, tested for drag use.
Consistent spring rate made by reliable Yamaha Factory.
Vixion Valvespring max rpm = 12,500rpm
Stock valvespring max rpm = 10,000rpm
See RPM on each Gear
http://www.youtube.com/watch?v=PNpCjsR-n9M
KAWAHARA CAMS
Tried and tested, used by indoprix.
With kawahara cams and vixion valvespring and cdi and pipe.
You will reach 135-140kph on stock bore 135cc.
plug and play.
http://www.youtube.com/watch?v=-4LeXpQoA6s
While Supplies Last
PM for prices and shipping
sir pwede po ba pa PM ng price ng mga yan? thanks..
red_is_karma
sir pa PM po ng price ng kawahara cams stage 1 at vicion valve spring at kung kelan ka magkakaroon ulit? kuha po ako kagad... TIA
j_caldeojr
Sir pa pm po ng price ng cams at valve spring.. Ok lang po ba kahit yan lang mods cams at valve spring tapos naka rcdi at naka pipe lang??
Tsaka po san po loc nyo sir? Tsaka nag iinstall rin po ba kayo hehehe..
Wait ko po Pm nyo sir ha sa price
Thanks po
dhom
Hello everybody,
I just installed
kawahara k1 cam
cms valve spring
racing gear 1,2,4
the setting i use are
in= 0.10
ex =0.15
and also i need to do valve pocket at the piston, becoz after my mechanic check it, he said in high rpm it might hit the piston, and the others is still standard including the sporket.
SO THE RESULT
It produce sort of nocking sound at the head, there is no power or pickup from gear 1,2,3 and 4. at gear 1 the timing seem not stable gear 2,3 and 4 is ok but still no power, its worse than my standard machine. at gear 4 when it at mid rpm the timing is not even or stable, i need to drop to gear 3 to make it better.
I thing its the standard carb setting, but my mechanic said its because of the low compression due to standard piston and block size and he advise to change to big block, i plan to check the plug to see how it goes. I really confuse for what had happend and really need your help guyssss...
PLEASE HELP ME..GUYSSSSSSSSSSSSSSSSSS
And i do appreciate if you guys can reply in English :(
spoke_bender
Sir Traxx
Please notify me once may stock na. 2 na kami sure na kkuha and still trying to convince the 3rd one.. :)
Thanks
hi all out of stocks for now.
@don
i think its because your mechanic pocket the piston which results to low compression.
k1 are safe to install directly no mods to piston needed.
