FS: Vixion Valvespring and Kawahara Cams (PlugnPlay)
rem
sir job txt ako 2morow morning kong 2loy ako jan ha.. tboli pa kac ako manggagaling. hehehe bka ma tanghalian.. ok lng bah?
allanboy_g
Admin, magkano po mtrt o Vixxion valve spring for my x1r.kasama na po shipping?LAguna area po ako.
ano po mas maganda performance,mtrt o vixxion?
TIA
Allan-09289981501
acidrain
sir traxx...what are the disadvantages of using racing cams?if there is any...
disadvantages?
magkakasakit ka ng MAD ^_^
para lumabas ng full potential ng naka cam dapat naka big carb ka, rcdi, valve spring r.coil. pero less maintenance naman ang ganitong set-up ^_^
rem
ung faito low cam advance tol. bka this sat isulan SK ako. may dragrace kac dun entry ung mga barkada ko
rowan
hi guys
For Sale: Vixion Valvesprings and Kawahara cams now available.
Plug and Play
VIXION VALVESPRINGS
Tried and tested for long rides, tested for racing use, tested for drag use.
Consistent spring rate made by reliable Yamaha Factory.
Vixion Valvespring max rpm = 12,500rpm
Stock valvespring max rpm = 10,000rpm
See RPM on each Gear
http://www.youtube.com/watch?v=PNpCjsR-n9M
KAWAHARA CAMS
Tried and tested, used by indoprix.
With kawahara cams and vixion valvespring and cdi and pipe.
You will reach 135-140kph on stock bore 135cc.
plug and play.
http://www.youtube.com/watch?v=-4LeXpQoA6s
While Supplies Last
PM for prices and shipping
hi traxx im rowan been avid fan of urs ,ur very dedicated helping guy for our t135. kindly pm me the price of ur vixion val spring and camshaft even kawahara cams.
hope u will give me good price . im going to buy from u directly. this is my email add rowan_anthony@yahoo.com # 09158942912
im going home mindanao after holyweek hopefully i can get this things from u.
Godbless saferide always
rem
OT ahahaha.. prang ayaw ko na sumabay ka jval papuntang gensan nxt tym ah.. mamaw of surallah kac hahaha..
vhadz
hi guys
Plug and Play
VIXION VALVESPRINGS
KAWAHARA CAMS
plug and play.
sir how po cam n spring individually,, tnx!! ride safe!!
