Fuel Gauge
mingomz
Sir, Madali lang ba tanggalin ung panel? also, possible ba masunog ung resistor?...
I will definitely troublshoot later regarding this.
Jval Zkie
just use soldering iron much better pag my paste ka para kapit agad. yung tip naman ng wire ng resistor solda mo not the resistor itself. dikit mo lang sya ulit sa rotor at lagyan ng mighty bond para di sya maalog (resistor). medyo tricky nga lang gawin pero kung may experience ka mag solda kaya mo gawin to. pag di ka sigurado sa gagawin mo pwede mong dalhin sa electrician yung panel at pasolda mo para sureness...
goodluck! sa DIY..
mingomz
jval15 said:
Yup! baklas lahat. 1st tinanggal ko muna yung side mirrors, tapos lahat ng screws then yung front portion kasama yung headlight. may 3 screws pa yata bago mo matanggal yung boung panel. ang isa you need long screw driver para ma reach siya. i open the panel and hirap ako sa pag tanggal ng pointers ng speedo at fuel kaya pinabayaan ko na lang. unscrew ko lang yung 4 na screws kulay black na maliit. nilihis ko ng kunti yung dashboard reachable naman yung resistor na malaki kaya solda ko na using soldering iron. tapos dinikit ko yung resistor sa housing ng rotor at nilagyan ng kunting rugby para di na siya aalog-alog. bago ko binalik yung boung panel check ko muna by moving up and down yung fuel sender sa tank. ok naman kaya yun. AYUS! solve ang problema.
@ TS:
Just want to share also my part. (maki join na lang po ako sa thread na to if you don't mind)
I though that the problem with my speedometer was the pin. Unfortunately it was not...
There is reading in my fuel gauge, yet it would only read until the middle of the gauge. Even if I have my tank at full it will only reach at the middle.
Same as jval15, I dismantled the head assembly and took out the guts and wires and pulled out the speedometer.
It's pretty difficult to unscrew the speedo from the back fairing and the back fairing itself... but nothing can stop us from a little determination and faith...
here is a picture of what it looks like with out the speedo. Just unplug the peanut bulbs, unscrew the speedo cable, and unscrew the retaining screws of the panel itself. ( there are about 3 screws)
Here is the picture of my speedo panel removed. The glass covering and the gray plastic inside can be easily unsnapped.
These guys (wires) go to the coil of the fuel gauge. I though this was the culprit of my problem.. sadly no..
Notice the silver screw, once you remove these screw you can now pull out the inner side of the panel
Here is my culprit..
According to my brother (ECE teacher) the resistor is a goner.
We get a reading from the small resistor, but for the big one we got a zero reading in ohms.
never thought electronics will haunt me again. never been good at this subject :(
My problem is..
anyone knows what is the big resistors value? the small one is 27 ohms.
We are still trying to manually compute it by it's color coding. It's just kinda hard to determine what color since it's burned out already.
Worst, even if we resolder a new resistor, the coil might also have been damaged.
currently my sniper is headless and I gassed up already to almost full so when I buy the needed resistor I will know if the reading is correct.
thanks for reading my post. Also hope this helps other folks who encounter the same issue. I will just update this thread of what ever happens. If this troubleshooting of mine does not work.. oh well better settle to buy a new speedo... =(
thanks..
mingomz
AT LAST na ayos ko din po.
it was the resistor.
just changed it.
everything is working fine.. =)
boldstardex
gratz mga sirs at naayos nyo din yung prob nyo..hmm..ask ko lng po,,ano kaya posiible causes ng mga probs ninyo?and ilang years na ba ung snipee nyo?pra atleast aware kami kung ano pde mangyari pag ngka prob yung fuel gauge din namin.hehe
mingomz
Voltage break down.
More common for resistors. they get worn out. take for example tv's refs..etc..
my snipee is 1 and half yr old. nasira ung resistor ko kasi nadikit ung busina ko sa ground last 2 weeks
I neglected the horn terminal sticking in to the metal when I was returning the components after I replaced fork oil.
moving forward.. alast, at least I have a peace of mind. =)
it would not even take more than a hundred bucks to repair this in the panel.
Jval Zkie
@mingomz
nice to hear that bro. you fixed it the other way and you documented it. it will be a great help to our brothers who might encounter this kind of problem in the future.
whats the value of the big resistor?
mingomz
i used a 3W 50 ohms. used for industrial antennas. so far it's ok. =)
just finished assembling and cleaning my operation. hays.. at least it was worth it.
