Gas Consumption After Modifying Your Sniper Engine....
Takumi13
Dahan dahan lang po ako magdrive,at hnggang 80kph lng. Kung irerejet ko nalang yung stock carb mas titipid ba?
grix
Smx
Stock bore&stroke
Shaved block .5mm
Brt hyperband rcdi
Vixion cam
Vixion valvesprings
Keihin PE 28 with 110mj 38pj
Nobi 3bold pipe
33kms per liter
City driving & cruising @ 80-100kph
Takaw
suplado010
Smx
Stock bore&stroke
Shaved block .5mm
Brt hyperband rcdi
Vixion cam
Vixion valvesprings
Nobi 3bold pipe
33kms per liter
Takaw
malake poh bah nagbagu sa lakas nung nagshaved kah ng block?
Takumi13
kulang lang sa tono carb mo..hanap kah magaling nah mekaniko...
2nd hand na po itong motor ko,nabili lang namin last december,di ko alam kung anung size ng jets nakalagay sa carb nito,ang alam ko lng 26mm ito, naka-engrave po ba sa jets kung anung size ng jet na yun?
suplado010
ou nakaengrave...patono mo sa magaling nah mekaniko..or i think normal lang yan kasi nakacarb kah..
Takumi13
May iba kasi dito nka 28mm pero nakaka 35-40km per liter parin,mas marami pa nga ang karga kesa sa motor ko.
Takumi13
Takumi13
Takumi13
I fill the tank up to its full level then i record its odometer reading,and then i use the bike(tipid riding mode),when its near empty,i fill the tank again to its full,record the amount of fuel filled and the odometer reading. I subtract the current odo reading w/ the previous reading,and i divide the total by the amount of fuel used.
casmot
Vixion kit
Shaved block .8mm
stock cdi / v spring
mtrt ignition coil
stock cam
stock carb rejet mj 107.5
43km/L
Takumi13
Pinacheck ko kahapon yung motor ko sa ibang mekaniko..kaya pala anlakas sa gas,122 main jet at 48 pilot jet ang nakalagay, pinalitan namin ng 115mj at 42pj(papalitan namin ng 40 or 38 kung kailangan),. Observe ko muna ngayon ang consumption.
