turbulence
adjust clutchIn my experience shifting goes smooth when im running on high speed.. example 30- 40 kph.. but when im below 20 kph or in idle... shifting is hard, gear hits something before its shifts.
adjust clutch
its the same bro,whether you are using mx or classic,its the same broand one more thing,no clutch levers were placed on the right side.the clutch adjuster located in the crank were on the rightside (classic) and left side (mx)if i am not mistakenim using sniper MX is that the same with sniper classic? if i remove the front fairings is clutch adjuster u saying is the same location in MX and classic?
if you are nearer,you can drop by my place,ill show you how to adjust the clutch...i can help you with that(then buy some of racingboy products)Can you post some pics or tutorial adjusting clutch ?
levers,etc
Is it necessarily to adjust the clutch using that lever u are saying? in my point of view its the same with adjusting the nut just above the crank case or is it different?if you are nearer,you can drop by my place,ill show you how to adjust the clutch...i can help you with that(then buy some of racingboy products)levers,etc
btw i just sold my classic sniper,and im using fino now
may be the same..Is it necessarily to adjust the clutch using that lever u are saying? in my point of view its the same with adjusting the nut just above the crank case or is it different?
yep i know. but its too much hassle if i need to remove the front fairing to adjust clutch, if i can just adjust it using the 2 nuts above the crankcase. if its different well its worth giving a try.!may be the same..
bro the levers what im refering about is the one youll always squeeze when using clutch and handbrakes,thats the lever bro![]()
if you are using stock levers, the easiest way to adjust your clutch is through you crankcase.Can you post some pics or tutorial adjusting clutch ?
one question bro? would i still be able to shift smoothly in idle ? ill squeeze the clutch lever then shift gears on idle.. when i do that now somthing is hitting or i feel hard shifting before the gear shifts... but when im running aroung 30kph its all smooth.. i reaaly dont know if they just fit 5gears to MX that suppose to be 4gears only thats why its not that smooth...if you are using stock levers, the easiest way to adjust your clutch is through you crankcase.
Here's the tutorial:
To adjust, first turn turn screw nut no.1 counter clockwise to 360 degrees as many as you needed to reach your potential adjust. then turn screw nut no.2 counter clockwise to lock it up. pictures shown below.View attachment 21920
on my experienced bro sometimes that's normal especially when the engine is not yet hot. what I always do is pump the clutch 5 times before shifting on idle and it goes smoothlyone question bro? would i still be able to shift smoothly in idle ? ill squeeze the clutch lever then shift gears on idle.. when i do that now somthing is hitting or i feel hard shifting before the gear shifts... but when im running aroung 30kph its all smooth.. i reaaly dont know if they just fit 5gears to MX that suppose to be 4gears only thats why its not that smooth...
so would it be safe to say thatyou cant over rev all stock sniper due to cdi rev limit. That normally sounds due to the shifting gears
i dont thinks thats over reving.. try to check your chains maybe its loosen.. that happens to me when i got a loosen chain... the chain hits the rubber in the swing arm.. when shifting.Noob question here sirs,
with your ALL STOCK sniper mx,
what's your gear shifting according to your mileage?
example:
Gear 1= 0-20km/h
Gear 2= 20-50km/h
i tried this with an all stock sniper mx:
Gear 1= 0-30km/h
and i experienced "tok" sound while shifting to 2nd gear.
but 30-60km/h in 2nd gear to 3rd gear there's no problem at all.
is it possible that i over revved?
TIA.![]()
i'll try to look on that sir, thanks a lot.i dont thinks thats over reving.. try to check your chains maybe its loosen.. that happens to me when i got a loosen chain... the chain hits the rubber in the swing arm.. when shifting.
what im saying sir is that there is no such thing as over rev on stock sniper using stock cdi. you can only over rev when you use racing cdiso would it be safe to say that
gear1 to gear2 = 0-30km/h is over revved for my all stock sniper mx?
IHMOi am NEW to mcs so i dont know if i am over revving already or not,bro buko0 how can you over rev with/using stock cdi??its not possible though it has a limiterIHMO
