ronnelmarc_21
Guys,
I just want to share to all of you this simple design for our t135. There are two revision there A and B.,..To those who want to have modification DIY on there signal light.
Description:
If the hazard is "ON" and you need to send a turn signal, just click the signal switch and will automatically give u a turn signal,..once you press the turn signal or "OFF" the hazard will be back,.you can send also signal like on stock signal even if the hazard is OFF.GOOD LUCK!!!!
Rev A.
1. two flasher relay --same with stock specs,,dependent on the signal bulb wattage. blink rate depend on the wattage of bulb.
2. two electronic relay -- NAIS relay or COTO relay for low power and better contact.
3. Rewiring
4. Ordinary switch for hazard
RevB
1. electronic flasher -- independent on load wattage.
3. Rewiring
Description:
Rev A.
3. Rewiring
RevB
3. Rewiring
