Hazard Light Switch Install
Hi guys!
I recently installed a hazard light switch on my Sniper150. (3 wire switch)
Its currently tapped to the switch and not the wire harness (Try to avoid messing with the wiring harness as much as possible)
When I turn the hazard switch on, both front and back signal/turn lights are on but are very dim and does not blink like it should when I use them as normal. They just flicker.( I have 2 LED back up signal light installed and mounted on my left and right fenders (drilled) as auxiliaries for better visibility )
I don't know if I need a new relay or just remove the 2 LED signal lights I installed. Maybe that will fix my problem?
Any ideas and suggestion is much appreciated!
PS. Could it be that the current draw is too much for the stock relay?
