EinVer
Hazard & Parklight Controller
for Sniper's stock signal lights, without losing signal light function
* easy to install, uses sockets that are compatible on sniper's stock wiring harness
* can use ordinary signal light bulbs or leds / power leds
* comes with free electronic flasher relay
* home-made
what it does:
- gives your 4 signal lights (front & rear) the parklight function in addition to the stock parklights. it is battery operated unlike the stock parklight that uses AC from stator which results in varying brightness
- parklight cancels out when you use your signal light
- another function is the hazard mode which also have the auto-cancel feature when you use your signal light
videos
http://www.youtube.com/watch?v=ZpPbRWMUXOI
http://smg.photobucket.com/albums/v731/ ... V00913.flv
http://i134.photobucket.com/albums/q90/ ... hazard.gif
pics
http://i134.photobucket.com/albums/q90/ ... HPCtrl.jpg
http://i134.photobucket.com/albums/q90/ ... C02016.jpg
http://i134.photobucket.com/albums/q90/ ... edbulb.jpg
http://img.photobucket.com/albums/v731/ ... C01012.jpg
http://img.photobucket.com/albums/v731/ ... C01023.jpg
http://i134.photobucket.com/albums/q90/ ... C02012.jpg
http://i134.photobucket.com/albums/q90/ ... C02013.jpg
http://i134.photobucket.com/albums/q90/ ... klight.jpg
- a toggle switch will be added for you to use the hazard & parklight function (included)
- for the meantime, shipping is limited to Philippines since im not yet familiar on shipping products overseas.
- per order basis, it may take 7 days to create 1 controller since im a student and got some other things to do
UPDATE
I've got a new compact model which only gives hazard function to make it more compact and cheaper
parklight function have been removed since Yamaha Sniper already have parklight in stock form.
Pros: (compared to Hazard Parklight Controller)
- compact in size, measures 2 x 3 x 5 cm
- less wires
- low cost
Cons: (compared to Hazard Parklight Controller)
- no parklight function for the signal lights
- no DC convertion for signal light indicator on panel
(DC convertion is needed if you plan to use all LEDs for your signal light)
- doesn't come with electronic flasher
Installation Video:
http://www.youtube.com/watch?v=OT8HhxX4JQM
* home-made
what it does:
videos
pics
UPDATE
- less wires
- low cost
Installation Video:
