Hi guys - I have manage to get it right on the ON/OFF switch for head light
1) Get the necessary tools and wires, switch, wire lug,PVC tape
2) Remove the front head light panel
3) Check for the red connector and unplug them. At male connector remove the blue cable (Pic1) and at the female connector remove cable yellow with red stripe (Pic2)
4) Take your time on the wire removing from the connector as it would damage the connectors if not properly done
5) Get a 2/3 pole switch and connect to this cable i.e blue and the yellow red stripe
6) The tricky part is the location where you want to place the switch. I have place it under the brake pump as shown pic3. At least there is no drilling required
7) Don't forget to connect back the red connectors and test the ON/OFF function before closing back the head light panel
8) Off you go and happy trying guys
http://i183.photobucket.com/albums/x88/kamalez/1.jpg
http://i183.photobucket.com/albums/x88/kamalez/2.jpg
http://i183.photobucket.com/albums/x88/kamalez/3.jpg
http://i183.photobucket.com/albums/x88/kamalez/4.jpg
http://i183.photobucket.com/albums/x88/kamalez/5.jpg
